"THE GREEN GOBLIN"
Straight 6 & V8 Engine Wire harness? "Pink Wires"
Hello guys me again
![]() "THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi ![]() Drive it like you stole it! ![]() Petey-pablo@sbcglobal.net |
Re: Straight 6 & V8 Engine Wire harness? "Pink Wires"
Here's a wiring diagram i got from another member. it should answer your question.
![]() On a side note, are you still using the original style distributor, or did you swap to HEI? Original - wire up exactly like diagram HEI - you will need to remove the resistance wire (there's a good writeup in the tech section).
2003 GMC Sierra 1500 WT 1995 Nissan Hardbody 2016 Hyundai Veloster Turbo DC2 (SW/AW) Clyde W. Harvey USN "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill |
#3 | |
"THE GREEN GOBLIN"
No I am not using the original style distributor I have a MSD with A Blaster Coil.. I have looked at this Wire Diagram already over and over and it does not show the wires on my harness I am talking about, Could be It's from a V8 My truck has the origanal Straight 6 NoN/AC Engine harness it came with.. This V8 Diagram Show 7 wire wich none of them are Pink the two that are tied up on mine. My harness has 6 wires as I stated a bove Thanks...
Active Member
![]() Join Date: Jul 2007
I'll check my 68 GMC. It has the original wiring on it.
When I changed to an HEI dis, all I did was add a 12 guage wire from the firewall connector to the pos side of distributor leaving the original dis wire in place. I left the rest of the wiring intact. |
Active Member
Checked my wiring. It's different than yours to some extent. I have 4 wires coming off the top. I don't have the wire for the oil sw and no wire off to the backup lite as the diagram shows.
The bottom half pretty much follows the diagram. |
"THE GREEN GOBLIN"
My wires still look nothing like the diagram pictured above I have 6 wires Heres some pictures Hope someone can help..... I have 6wires 5 pins The two Pink wires are tied in to the sam pin... The Smaller Pink wire is the one labled Resistance Do Not Cut So my guess this one would be for the Dizzy, But the biger one I have no Idea where it goes..
Here's the whole diagram if you want that too
The Older Generation
I don't think those wires are pink I think they are faded red. Here is a picture of a switch harness, the top wire is faded red and the bottom wire is pink. LockDoc
the brown and white wire is your horn wire and the big red wire goes to your voltage regulator and your alternator.
I've got a pink wire in mine too, but mine is tied to a white wire also. I was thinking it is the wire going to the starter/coil that is labeled 20w/ or-ppl ?
sorry I just realized how bad my pics are.It's hard to tell but the wire on the far right is a purple wire, the pink and white one's are to the left of the purple. Also my v.i.n say's my truck came with a v-8 but I pulled a six out of it.
"THE GREEN GOBLIN"
I am talking about the Engine wire harness Not the Horn and Light harness thanks, I will try to take a Better Picture Later today These were taken using a Camera Phone. I will use a real camera today thanks. I am Just wonder ing where these wires go..
"THE GREEN GOBLIN"
Did they make diferent wire harnesses for Straight 6 Motors besides Ac and Non /Ac trucks? So far from what I have seen no one has a simular harness.. These two wires are Ignition Hot Only Not Constant Hot...
#14 | |
Active Member
Re: two pink wires. You say ignition hot only? Doesn't make sense. If they're tied together and the resistive wire is for the points distributor, then both should have 12 vdc. Maybe someone messed with the wiring in the past?? In my truck, if some future owner were to look at my harness, they may see a blue 12 guage wire for the HEI on the same connector with the resistive wire -It was the only 12 guage wire I had. Last edited by 68gmsee; 02-20-2009 at 10:13 AM. |
