02-19-2009, 08:22 PM | #1 |
front clip
Hello I,m new to this web site but like what I see. My question is can I R&R a 83 truck disc brake front cross member to my 66 front cross member or should I just buy new drop spindles to convert?. Thanks Greg
02-19-2009, 08:47 PM | #2 |
Happy to be here
Re: front clip
Welcome to the forum gregwestby. I think you will get a quicker answer to your question if I move this to the 60-66 forum.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 02-19-2009 at 08:48 PM. |
02-19-2009, 08:59 PM | #3 |
Re: front clip
You can use the crossmember out of the 83, but I think its alot of work when you can get the drop spindles and just convert it. Thats what I'm going to do with my 66, if I ever get around to it.
02-19-2009, 10:06 PM | #4 |
Hey Y'all!!
Re: front clip
Greg-If you plan to drop it, I would go ahead and buy the drop spindles. More than likely you would have to buy all of the same replacement parts for the 83 stuff as you will to install the new spindles.
66shortstep-When'd you get a new project?
Just hopin' I live long enough to finish something!!! |
02-19-2009, 11:08 PM | #5 |
Re: front clip
Awhile back. Its just a cab and frame. It will be awhile before I start it. Click on my name and hit profile, and go to my pics. I have a couple of pics of it. Last edited by 62 short step; 02-19-2009 at 11:10 PM. |
02-20-2009, 01:36 AM | #6 |
60-66 Nut
Re: front clip
The crossmember swap isn't too bad to do if your engine is out. The advantage to swapping the whole crossmember is some upgraded parts such as larger LCA shaft U-bolts, rubber control arm shaft bushings as opposed to the steel ones. But if you're wanting dropped spindles anyway, that would be the better way to go to start with.
