02-20-2009, 05:24 PM | #1 |
Help with a spindle debate...
A guy I know with a 65 chevy truck says a guy "who knows" told him he just bolted up 73-87 drop spindles directly to his 64 a-arms....
I said I didn't think it was possible. But I also don't remember all the gory details you guys have spelled out on this board. And didn't have time to search it out. So I'm asking....Is it possible??
Tim Road Hounds |
02-20-2009, 05:31 PM | #2 |
Lowered in Cleveland
Re: Help with a spindle debate...
On my 66 I used 82 spindals, I just had to use 82 upper and lower ball joints, they were all mounted to my original upper and lower control arms.
02-20-2009, 05:31 PM | #3 |
I know you can on the 67-70 but you have to use the 73-up ball joints and tie rods. I don`t see why it wouldn`t work on a 64-66. Another option is replacing the entire front crossmember with a later year. It bolts right up with one new hole per side to be drilled.
Anthony |
02-20-2009, 05:32 PM | #4 |
From what I have read you could change the ball joints to the later model and bolt the spindle up. But then I believe you will have to change outer tie rod ends also. Maybe somebody else can confirm.
Michael |
02-20-2009, 05:49 PM | #5 |
Yeah, you have to use the later outer tierods but to do that you need a special adjusting sleeve. here's a link talking about the sleeves... Or you can get the whole steering assy from a 71-87 truck.
http://67-72chevytrucks.com/vboard/s...d.php?t=328438 Good luck, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer - https://67-72chevytrucks.com/vboard/...d.php?t=856475 '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743 Last edited by raggedjim; 02-20-2009 at 05:50 PM. |
02-22-2009, 02:01 AM | #6 |
60-66 Nut
The '73-'87 ball joints will fit the '63-'72 A-arms, and just use the complete '73-'87 steering linkage. Just have to drill holes for the idler arm
