Future TOTM Winner
Blazer tub weight
Does anyone know the weight of our tubs? I'm talking completely stripped down of interior, trim, firewall junk, etc. The only think that might be left in it would be the windshield in my case. I'm thinking 300-400lbs...but I may be an idiot.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
Re: Blazer tub weight
I'm thinking closer to 1000 lbs. They are pretty Heavy.
urban fourwheelin
agreed.
1972 K5 Blazer with Cummins 4BT, NV4500 swap in the parts gathering stage. |
Future TOTM Winner
I will take yalls word for it, I have never had one stripped down to that level. Just doesn't seem like that much metal would be left once stripped but I guess so. So I guess we are talking about 4 guys to move it around by hand.
The LuvShack Garage
Or ...........................................................................
One of those 1 man cab dolly thingamajiggers ![]()
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
![]() Join Date: Jan 2007
1 man cab dolly things = 3 guys still holding the tub -
![]() Then again when they are in that good of shape - I would have done the same thing... |
Pulled mine with the top still on with an engine hoist, worked good but I only lifted it 'up' and then pulled the frame out from under it, then right back down again.
What do you have or going to get for the cross pieces? I've also moved one with a wrecker, that too was easy. ![]() |
#9 | |
Future TOTM Winner
As far as cross pieces, I guess you mean what sort of "bracing" have I added to avoid the above mentioned buckling? I am working on a 1" square tube structure that will connect the door openings with the bed panels with the floor with the tailgate opening. That's why I ask the weight question. My background tends to make me over-engineer things when I am unsure of all the variable. If I'm not careful I will have an I-beam structure on there strong enough to lift a bus. ![]()
Wide n'Low
I am not sure of the weight either, but here is how mine just went frame off and then back on.
The front clip was off, but it had the following still in place. the windshield Double wall top laying in the rear were the bucket seats rear seat tailgate bumpers. And so we used an engine hoist 3 30gallon barrels one large railroad tie, and a few lengths of 4x4 lumber First we attached a chain to a bolt on each front support mount seen in this picture (look for the large bolt and washer on the vertical support) ![]() We shortened the chain enough so that the top off the hoist fell just below the firewall lip at the top of the recessed arch. The we hoisted it up enough to insert the railroad tie under it and on top off the barrels. On each of the front barrels we placed 3 samll 4x4's to help the lumber sit flat. Then on the rear, we used the chain and clevis pins attaching them to the tailgate latches. To support the rear, we used one barrel and placed several cris-crossed pieces of 4x4 until it was approx. that same height as the front. You can just see them in the corner of this shot ![]() Worked like a champ! Just make sure to keep the barrels on the front wide enough to roll the chassis out!
Trippin Hazard.. 67 swb, Gold Member.. 68 Suburban Air Force Retired |
#11 | |
I was referring to whatever it is you plan on using 'underneath' when lifting. The tub won't fold on you, especially since your floor & boxes are intact. I used the two front & two rear body mount bolt locations and ran a chain between each of those, then ran one between those two down the center. Used two ratchet straps that went from the hoist to either side but wasn't feeling safe with even all that. Ended up adding a come-along from the garage floor joist's to the firewall for stability. All I was doing was lifting straight up and back down, moving them around is another creature to wrestle. |
The LuvShack Garage
Only because we had to tilt it to clear the 35" tires, if we could
have taken the cherry picker higher (ceiling) then NO hands on.
Its lookin' like a Blazer!
Right now I'm using a engine crane with some chain. 4 attatch points, through the rear floor where the seat cross brace is and in the front at the front seat bolt down points. Just 4 bolts going through the chain, the crane is sittin' center where the floorboard meets the bed. I think there are pics in my thread. My tub is solid so you'd have to do some bracing if yours is not, unless you leave the top on. Its not a perfect balance but I use just a little weight here and there to level it up while its in the air.
#14 | ||
Future TOTM Winner
![]() Quote:
That's good advice. I was originally planning on building some sort of bracing structure and also using it for lift points. However, what you have said makes more sence. Brace up the body as needed and lift from the body mount points. Originally I planned to brace it up, remove the tub, have it media blasted, then tackle the sheet metal. After thinking more about it, I think I will fix the floor/rockers while it is still on the frame, then remove it just to be safe. I recently changed the body mounts and got them shimmed properly (thanks to Huck!) so the top sits straight. My floors aren't that bad compared to some I have seen and my torsion boxes seem to be fine, but I don't want to take a chance with everthing buckling when its 4 feet up in the air. ![]()
#15 |
sharp as a marble
Critter, The company that media blasted my Chevelle was
master blaster. they are in Orlando Florida. Just for kicks you might give them a call and ask how much? |
#16 |
I'm a poor spectator
I don't think they weigh as little as 300 but I don't think there is any way they weigh 1000 pounds. 600 tops.
2006 Jeep Unlimited IMPACT ORANGE 1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig ![]() 1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!! ![]() 1979 Ford F150 4x4 SWB Built Ford Tough!!! ![]() 1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!! |
#17 |
Future TOTM Winner
Ohhh...just realized something. It might be hard to roll the frame forward or back with the cherry picker legs under everything. Luckily I have been looking for a reason to buy some of these.
#18 |
Wide n'Low
You mentioned building a body cart of one sort or another, I found some plans online and posted this link.
http://www.streetrodderweb.com/tech/...art/index.html Looks doable, I was thinking of making one of these for my project with some bigger wheels to roll on gravel..
#19 | |
Future TOTM Winner
As slow as I am I’m SURE it will be a while before I’m ready to put the tub back on the frame. This should make things a little more convenient while it’s under construction.
#20 |
I'm looking to pull the bare tub off my 72 blazer. I'm trying to do this in my 1 car garage. The rafters aren't up to the task but I'm thinking the walls should be. They are cinder block, my thought is to bolt L channel to the wall using expanding inserts and then use square tube across the 10 ft span. I'm thinking 2 pieces of 2x2 tubing ( 10 ft span point load is close to 600 lbs) should be up for the task of holding the tub up. Anyone done this? Anyone have a reason I shouldn't?
#21 |
![]() Join Date: Jun 2014
personally just used the engine hoist method and had a wooden cart to hold the tub. Worked great. I had my wife push the hoist while I lifted the rear/side to get it over the top.
1970 1/2 ton 4x4 4spd Suburban 1972 K10 350/700R/205/ Sniper EFI Daily Driver Sold 1971 K5 on 35s Traded 1972 K5 3/4 ton PROJECT Sold Last edited by Lieferson; 04-19-2016 at 10:44 PM. |
#22 |
And the cart I built. Don't know how to rotate the pics but it was only about 50$ to make
1970 1/2 ton 4x4 4spd Suburban 1972 K10 350/700R/205/ Sniper EFI Daily Driver Sold 1971 K5 on 35s Traded 1972 K5 3/4 ton PROJECT Sold |
#23 |
Oops forgot the pic
#24 |
is the tub gap between the bottom board and the ground enough to slide the engine hoist under it to set the body down on it from the side?
#25 |
yep, cleared my hoist by about 1/2 inch. it was perfect.
