Old member
Power brake booster
Ok after reading this I'm wondering if my new booster is bad.
http://67-72chevytrucks.com/vboard/s...d.php?t=182131 I bought a new booster and master cylinder a couple of months ago. When I first crank the truck and put my foot on the brake it whistles at me. This is the only time I have noticed it though. I haven't noticed it doing it once I start driving it.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
I have a radical idea!
Re: Power brake booster
It could be, but sometimes putting your foot on the brake causes another, smaller leak to show up. My '69 C-30 ramp truck did the same thing a while back and the whistling was actually coming from a rubber vent cap on the carb that was dry rotted. I would check all of the other vaccum lines before pulling the booster off. How are the brakes actually working?
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
Old member
The brakes seem fine. It only does this at first startup after that I haven't herd it. I have fuel injection so I will check other vacuum lines also.
