sufficiently talented fool
![]() Join Date: Jun 2006
? for small block to big block swap
I pulled the 283 out of the "72, and installed a 454. It is in and bolted up using the small block mounts. Everything fits fine...except the headers. The right header clears everything fine, the left header is hitting the engine perch...BAD. I am not against denting the tube a little to introduce some clearance, but I would have to cut the front tube in half to get around this one. I have a '71 Suburban with the correct big block perches, but I don't want floor clearance issues with the TH400 trans, and also need the hood clearance for the blower. Anyone have any ideas or solutions for this dilemma?
Thanks! Bob
"it's impossible to be surrounded by idiots when you are part of the circle" ![]() 2003 Suburban 2002 Pontiac Montana 1981 Corvette 1966 Impala Convertible Click here to support the board |
Re: ? for small block to big block swap
You can cut the SBC mount and use a piece of pipe to get the curve of the 69-71 BBC mount and then the header will clear. I don't think the BBC mounts raise the engine that much?? I have seen the above mod done to a SBC mount in order to allow the BBC header tube to clear, I wouldn't beeat on the header, just make the mount fit around the tube??
I was thinking about that. I have a plasma cutter and a mig, so it would not be too big a deal, but was wondering if there were any other avenues first. That may be the way I go.
![]() Join Date: Oct 2002
I think you can use 73 up 350 mounts that are almost the same as 72 bb mounts and only have to drill one hole for each side.I bought a 71 gmc with a 454 and thought it had correct 72 only mounts until closer look it had 2 humps spaced instead of 1 in the center like 72 only.
Project '67 454
I'm using frame and engine mounts from a '86 s/b suburban, the upper holes line up and you must drill a lower hole. i'm using Flowtech headers with no clearance issues
Project '67 454
Here are some pictures,
looking good thats exactly what I was talking about.
Wide n'Low
![]() Join Date: Jan 2007
That's good news, i was just going to go find my 77 350 towers/mounts to put the 454 in my 70 Blazer project. I had heard that this combination worked.
Thanks Drew
Trippin Hazard.. 67 swb, Gold Member.. 68 Suburban Air Force Retired |
hey centless, do you have a build thread.
I did a blown big block swap last year in my 72. love to see some pics and specs. |
#10 | |
The place where you made your stand never mattered. Only that you were there... and still on your feet.
Stephen King |
"THE GREEN GOBLIN"
I used 72only big block mounts with flowtech hedders with No clearence problems On my 72 truck
![]() "THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi ![]() Drive it like you stole it! ![]() Petey-pablo@sbcglobal.net |
ASE master tech/machinist
I jumped on this late, I did one and swapped the mounts side to side, had to drill two holes, but it fixed the issue.
#13 | |
Wynne 70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s. Build thread 53 Chevy shortbed 69 Camaro Click here to subscribe Chevy GMC International Truck Club Louisiana Charter Member http://www.louisianaclassictruckclub.com |
RIP Mr Ron
![]() Join Date: Dec 2005
What happened. Any progress on resolving the problem.
Ron (Mr Round Tuit) ![]() Be kinder than necessary, for everyone you meet is fighting some kind of battle TN Message Forum TN Facebook Group SETN Truck Show My Photobucket |
