Wide Eyed User
Wrong year bed!
Thanks for this guys!
I removed the bed last Sunday and realized the entire bed is the wrong year. Which years had the narrower frame rails? I might be looking for a swap.. or just leave it??? Pro's - Cons?
1962 Chevy P/U SB Fleetside 350/350 2.5/5 static drop My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=294723 Final (as final can be ![]() |
Resistance is Futile
Re: Wrong year bed!
If your fab skills are decent, you could move the mount or make new ones. The other option is getting a new rear cross sill......maybe more work, but if that one is shot it mite be better. I think a bed mite be hard to find.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
Wide Eyed User
Re: Wrong year bed!
I don't have a picture, but I tack welded a cross brace in place across the back of the frame. Didn't have time to finish the weld. But in any event, those mounting points sit on the cross brace now and can be mounted to it.
chrome makes it go FASTER!
Re: Wrong year bed!
Pro's: You are wearing safety glasses!
Con's: The Micheal Jackson one-glove is SO dated ![]() ![]()
She can't cook and she won't clean. But she looks good in a skirt and she brings me beer. She can stay for now. EDIT:: But she left me anyway, So forget her. 1962 GMC Stepside V6 4 speed My rolling resto thread http://67-72chevytrucks.com/vboard/s...d.php?t=324226 My old farm truck http://67-72chevytrucks.com/vboard/s...=1#post3465005 Last edited by retodd7711; 02-24-2009 at 07:16 PM. |
Its Deja Vu time again
Re: Wrong year bed!
What the heck was there before? Since you said you removed the bed. Was the bed hoping up and down on bumps.
#6 | ||
Wide Eyed User
Re: Wrong year bed!
Ummm.. Yup...lol.. It just lays on the rails right now... BUT I don't go fast over bumps..lol..
![]() Join Date: Sep 2006
Re: Wrong year bed!
http://www.mar-k.com/catalog/catalog...=19621962CW-86 This one is for a 62..
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
#8 | |
Wide Eyed User
Re: Wrong year bed!
Funny, I never noticed that NONE the mounts lined up. Guess because I just had it sitting on the frame. is this a later year bed? I am guessing the new sills for correct year are a direct replacement?
#9 | |
Re: Wrong year bed!
what you have are 63-66 sills. i found all this out the hard way too
![]() ![]() Last edited by joe231; 02-24-2009 at 11:30 PM. |
Re: Wrong year bed!
there is also a difference between chevy and GMC isnt there?
![]() 71 GMC Long Bed, 454,factory everything, lowered, and shaved. 64 GMC Short Bed (great grandfathers truck) 65 Chevy 1 ton Dually a/c p/s p/b v8 auto 89 Jeep Cherokee 3" lift 79 MG Midget (My 7 year old vehicle) 29 Ford Model A Rat Rod (in the works) 86 pontiac fiero 2.5 manual18 year olds) 87 pontiac fiero SE 2.8 auto (18 year olds) 90 Mitsubishi eclipes turbo AWD (18 year olds) 69 BMW 1600 (wifes toy) |
Re: Wrong year bed!
just the name on the gate, i believe
Re: Wrong year bed!
Yep your right Joe!
Daddy Mack Joe is spot on, bedsides, front panel, tailgate, wheel tubs all will work. crossmembers and rear sill are the only difference. I know too as I picked up a 63 bed and then found all the cross members etc off ebay. or you can purchase the repop stuff. if your sides front and tailgate are good hang on to them. It is tough to find good OEM stuff.
________________________ 62' ![]() 08' Chevrolet Silverado CrewCab 05'Toyota Tacoma Prerunner SR5 Last edited by 62ChevyStep; 02-24-2009 at 11:41 PM. |
Re: Wrong year bed!
thanks 62!
BTW, all the Mar-K stuff is made in the USA, and i have heard it is good quality....
Wide Eyed User
Re: Wrong year bed!
best way to cut those welds? Plasma cutter or grinder? hmmmm
#15 |
60-66 Nut
Re: Wrong year bed!
Which welds are you referring to? Lower rear bed corners to the rear sill?
#16 |
Re: Wrong year bed!
i wouldn't use a plasma.....i would use, and have, a thin cut off wheel on a grinder
#17 |
Hey Y'all!!
Re: Wrong year bed!
Just hopin' I live long enough to finish something!!! |
#18 |
Re: Wrong year bed!
They are shallow welds and easy to cut.
#19 |
Re: Wrong year bed!
I figured it out the hard way after taking a small cut off wheel to mine without really looking. Anyways heres how I did it.
http://www.links4jeeps.com/chevytruck/news.php?id=61 Last edited by kizer; 02-25-2009 at 11:31 AM. |
#20 |
Wide Eyed User
Re: Wrong year bed!
excellent! that little minnie hacksaw does it huh? Well that's what I have a kid for...lol...Thanks guys!!
1962 Chevy P/U SB Fleetside 350/350 2.5/5 static drop My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=294723 Final (as final can be ![]() Last edited by DaddyMack; 02-25-2009 at 12:02 PM. |
#21 | |
Re: Wrong year bed!
#22 |
Re: Wrong year bed!
Well I wouldn't say it does it. It did do it and my arm felt like it was going to fall off. I just could not get anything in the gap and it drove me bonkers.
#23 |
Re: Wrong year bed!
Yeah, but when I tried a saw zaw it was hoping all over the place and since the cut is only 1/2 inch or so deep I had an issue guiding it and when I did get it to fit it was trying to cut to deep into the 90degree bend beyond the lower support and you have to hold it tight and at an angle forward to keep from cutting the bed side.
All I know is if anybody can do it with a Saw Zaw they are more or a man than I'll ever be. Well at Saw Zawing hahahahah. Last edited by kizer; 02-25-2009 at 03:13 PM. |
