Old 02-25-2009, 10:22 AM   #1
Lemield
Lemield's Avatar
1970 Factory Auxiliary Tank
Way back in 2006, I posted a picture of my 1970 C20 in a thread that was talking about factory auxiliary gas tanks. Unknown to me until a couple of days ago, a couple of board members asked questions regarding my truck. I recently saw another thread about auxiliary tanks so it inspired me to go out and take some pictures of mine. I do believe that this is a factory tank installation. I have never seen another one...so maybe it was dealer, although it's on the glovebox sticker.
My apologies for not answering the questions....I think you asked for pictures so here they are.
Larry
1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green"
1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red"
1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon"
2005 VW Beetle Diesel 44+ MPG "Silver Bullet"
Lemield is offline   Reply With Quote
Old 02-25-2009, 11:26 AM   #2
70 Suburban
Rods
Re: 1970 Factory Auxiliary Tank
i know that there were some... im not sure if that is where it was placed. I looked it up in the fsm. they call for a saddle tank. that is in the same location as the blazer. where is your tank switch at
70 Suburban is offline   Reply With Quote
Old 02-25-2009, 11:27 AM   #3
Kayotic
Kayotic's Avatar
It's about time... LOL
You wouldn't know the size would you?
Anyone got something to add to this. I would like more info, Please...
Come to think of it - First we had the filler neck and gas tanks in the cab. Then we had a filler neck right above the tail pipe,, Boy times sure were simple back in the day...
Atlanta Craigslist
Hurst Indy Pickup Truck 3-Speed Shifter - 5010016
Kayotic is offline   Reply With Quote
Old 02-25-2009, 11:38 AM   #4
Lemield
Lemield's Avatar
Guys, Honestly I don't know what size the tank is....I really think it is a blazer tank.....but I do believe it is factory installed.
My tank switch is a lever on the floor by the drivers door. It has a tag on it and it looks factory too. I don't know if there was originally a switch for the gas guages somewhere else but I have a toggle switch mounted in the dash that the previous owner looks like he added. I will try to get a picture of both switches tonight.
Larry
Old 02-25-2009, 11:59 AM   #5
70 Suburban
Rods
nope thats factory. factory put the switch on the floor.
Old 02-25-2009, 12:26 PM   #6
Lemield
Lemield's Avatar
Was there a factory switch for the gas gauge?
Larry
Old 02-25-2009, 12:34 PM   #7
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: 1970 Factory Auxiliary Tank
At least In '72 there was a switch on the far left of the dash by the drivers door opening w-strip.
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze poly, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD Kelsey Hayes wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion..
2017 Sierra 1500 SLT 4WD, Black, 46k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 67k miles, 3.6, 8L45, 3.23 LS, 18" wheels
1970cstblazer is online now   Reply With Quote
Old 02-25-2009, 03:04 PM   #8
john
member #16
john's Avatar
Heres a pic I saved of a factory install.
john is offline   Reply With Quote
Old 02-25-2009, 03:19 PM   #9
Lemield
Lemield's Avatar
Definately a different location for the filler than mine. Here is a thread that discusses the 1970 aux tank.
http://67-72chevytrucks.com/vboard/s....php?p=2979585
Larry
Old 02-25-2009, 03:21 PM   #10
1970cstblazer
That is the fill location for the factory aux. fuel tank in '72.
Old 02-25-2009, 07:22 PM   #11
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
never seen that one before.
Learn something every day.
Old 02-26-2009, 10:06 AM   #12
Lemield
Lemield's Avatar
Switch locations and another underneath picture...complete with some sort of weed hanging off the rear of the frame...
The dash switch looks like it was added later...it just switches the sender units. The switch is the one with the white label. The other racing style switch is for an electric fuel pump that the PO installed by the rear tank. If necessary, usually on hot days, it can be switched on to help the stock fuel pump.
Larry
Old 02-26-2009, 10:10 AM   #13
Kayotic
Kayotic's Avatar
That looks like cat fur!!! Meow
Atlanta Craigslist
Old 02-26-2009, 10:13 AM   #14
Lemield
Lemield's Avatar
Sure does....let me think....yep, that might have been the thump sound I heard the other day...just kidding!
We do have some foxes that cruise this area...maybe it's fox fur?
Larry
Old 02-26-2009, 11:05 AM   #15
DANTIP
DANTIP's Avatar
Very Interesting!
Notice the line on the SPID for the side-mounted spare. The space normally occupied by the spare is taken by the auxiliary tank. I also like the label fastened to the rocker.
Dan
DANTIP is offline   Reply With Quote
Old 02-26-2009, 05:31 PM   #16
I missed that other thread about this.I dint know dat.Makes you wonder why they stopped.No auxilary tank in`71?It sure makes you wonder why.
Old 03-31-2009, 04:31 PM   #17
gary2232
Ok I have a 72 Longbed with a tank mounted between front of bed and rear wheel on driversside,with tank switch on floor by door. The filler tube is in wheel well opening. Is this a factory tank???
gary2232 is offline   Reply With Quote
Old 03-31-2009, 04:57 PM   #18
Longhorn Man
if it is listed on the SPID, then it was factory installed, if it isn't mentioned, then it isn't factory installed.
Yours sounds like it is not factory, nor even dealer installed. Probably something out of the catalogs from back in the day.
Old 03-31-2009, 05:28 PM   #19
gary2232
If the SPID is the list on glove box door it is gone. But to me it looks after market. It is made with square corners and welded instead of stamped or formed. Thanks for replay Longhorn.
Old 03-31-2009, 07:37 PM   #20
That would be an aftermarket installation.Some filled in the wheelwell and others filled behind surface-mount doors.The only factory auxilary tanks were in`70,like this one,and`72 like the blue and white truck shown.Both filler through the body like the main tank with the filler neck running down inside the bedside behind a steel cover.
Old 03-23-2014, 03:20 PM   #21
19702wdc10
Active Member
In 1970 was the rear aux tank every put in a C10?
19702wdc10 is offline   Reply With Quote
Old 03-23-2014, 06:35 PM   #22
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Good question, the three I'm aware of were all C20 3/4t trucks. It was not available in trucks with upper (beltline) moulding.
Old 03-23-2014, 07:06 PM   #23
DANTIP
DANTIP's Avatar
On the other thread (link above), someone was quoting from the 1970 Truck Data Book and it did say C/K 20 series only. Cool option!!
Old 03-23-2014, 07:12 PM   #24
SS Tim
SS Tim's Avatar
1970 Sales Data Book lists them in the CK10 section with the only restriction being to chassis cab or pickup applications. Makes sense as it was about the same as the Blazer and Suburban/Panel tank setup.
OK I found the bit about the stripes and moldings quoted from the 70 TDB.
SS Tim is offline   Reply With Quote
Old 03-23-2014, 07:22 PM   #25
gale
I'm not sure about 1970 but I bought several C10 trucks new and ordered them with an auxiliary tank. All were step side beds.
Later (1979 or so) had a rocker switch on the dash to toggle between tanks. It operated a solenoid valve and also switched to the other sending unit.
I was buying a new truck every year at the time so I don't recall which one did what but one year changed from a simple solenoid valve to motor driven worm screw valve. Instead of just toggling like on/off you had to depress the switch and hold it while the valve screwed open or closed. I didn't read the manual until I was stranded because the tank didn't switch.
Gale Gorman
'54 3100
'67 C20 stepside
gale is offline   Reply With Quote
