02-25-2009, 02:21 PM | #1 |
250 i6 mated to a muncie m21
i have a 68 c-10 long-bed w/ 250 and sm465 its my first chevy truck. I really dig the little straight six and have been doing a lot of research on it to get power from it, but i don't like the trans that's in it at the moment i want to keep it a manual does anyone have some info they'd like to share on what i need to make a muncie m21 or 22 work
02-25-2009, 04:03 PM | #2 |
ASE master tech/machinist
Re: 250 i6 mated to a muncie m21
Remove the granny tranny, and bolt in the M-21. You'll need a different drive shaft and shifter. Most of the M-21 units had a TH400 driveshaft yolk. The stock cross member mounted bell housing clutch etc will work. I've done it before, the biggest problem is the shifter. Most affordable 4 speed shifters are way too short and your knuckles will drag the floor. I would also add some form of a rear cross member for added support, the stock bell housing mounts will work fine, I just don't like the idea of a high dollar Muncie hanging out in the open.
"I sit here and I pray in my broken down Chevrolet....." |
02-25-2009, 04:24 PM | #3 |
thanks for the info this will be my first trans swap the main concerns were the bell housing bolt pattern mating to the trans it self, the input shaft, clutch & fly-wheel, the rest i figured wouldnt be to bad to get to work.
do you have anyother concerns? i should look for |
02-25-2009, 04:58 PM | #4 |
I'd make sure the throw out bearing is new, and double check the rest of the clutch. Spend your money on a quality shifter, you can get a mechanism from hurst fairly affordable, then choose a handle that fits your truck and arm length. I used the universal indy 4 speed shifter in mine. The indy is affordable, and you can still order a stick that fits. Shifter pn 5030030, and browse the catalog at your local speed shop for the handle of your choice. Finding a drive shaft can also be a pain, I used one out of an automatic truck, if I remember I had to shorten in a bit, but can't really recall. If you can fabricate you can shorten it, or your local drive line shop can do it, around here it's about a hundred dollar bill. I would also recommend re-sealing the trans, and new u joints and a pinion seal on the diff if needed. It is really alot easier than it sounds, about 3 hours worth of work, that included massaging the shifter hole to fit the side loaded stick. Hope this helps and does not confuse you.
02-25-2009, 05:20 PM | #5 |
cool thanks again like you said it seems to be easier than i thought so now im gona start my quest for a trans swap
