02-25-2009, 10:04 PM | #1 |
73 door swap question
I have a 73 c20, I read on a different site that only doors from 73-76 are interchangable. I have an 85 suburban sitting in the drive way, what is the difference in the doors other than the door panel area?
02-25-2009, 10:14 PM | #2 |
Re: 73 door swap question
other then the door panel area nothing at all
02-25-2009, 10:16 PM | #3 |
02-25-2009, 10:20 PM | #4 |
Would you happen to know what years are interchangable for most parts? I need 2 doors, front fenders, a hood, and tailgate. I saw a post for an 86 bed (wide?) and was interested in it. Maybe a site that can help better then the ones I have found?
02-25-2009, 10:35 PM | #5 |
Yes the doors will fit for sure,fenders and hood will have to be from a 73-80 model truck.The 86 bed will fit also .Now with a little work (providing the suburban parts are good) you can put the whole front end on,it will pretty much bolt on the trickiest part is mounting the hood hinges in the cab
02-25-2009, 10:37 PM | #6 | |
The One And Only !!!
I asked BB73 (Jeff) about this a while back when looking for a cab shell for my 74 (he knows his stuff) and this is the reply I got;
Maybe you should go back to that other site and set them straight on parts interchanging. LOL
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
02-25-2009, 10:58 PM | #7 |
yeller
73-76 door guts are different than 77-87 (88-91). The 73-76 window crank stalks are shorter, roller channels welded to the inside of the door are different as are the window regulator rollers themselves. Of course the door panels are different too.
You can swap complete 85 doors to your 73 no problem, it is when you start interchanging parts that you will run into trouble.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale Last edited by bigblock73; 02-25-2009 at 11:00 PM. |
02-25-2009, 11:00 PM | #8 |
Ok I'm confused now. Will it work with using everything? Like taking the whole door off, window and all and just bolting it on the 73
02-25-2009, 11:01 PM | #9 |
yeller
I edited my post while you were typing your reply...look above.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
02-25-2009, 11:19 PM | #10 |
02-26-2009, 08:24 AM | #11 |
Yes, change it all. I put some electric '86 doors on my '73 before I had it repainted.
