Old 02-26-2009, 08:44 AM   #1
herodcreekfarms
spring pads, if thats what their called
i was just wondering what the plastic or rubber pads between the leaf spring were made of and where i could purchase some. thanks for any light you can shed on the topic
herodcreekfarms is offline   Reply With Quote
Old 02-26-2009, 11:34 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: spring pads, if thats what their called
I belive they are Delrin which according to Wikipedia is atually Polyoxymethylene (POM), This is an engineering plastic, a polymer with the chemical formula -(-O-CH2-)n-. It is often marketed and used as a metal substitute. Delrin is a lightweight, low-friction, and wear-resistant thermoplastic with good physical and processing properties.
I would check with the local auto parts, or spring shop.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-26-2009, 12:52 PM   #3
MickMc
MickMc's Avatar
Poises for spring liner...http://www.posiesrodsandcustoms.com/
Spring pads, equals spring shop only, find your local big truck spring company, they will have them.
Mick
MickMc is offline   Reply With Quote
Old 02-26-2009, 11:27 PM   #4
leftcoast66
leftcoast66's Avatar
They use them in racecars and such. Its stiffer than polyurethane but not as stiff as metal. BMW's use them in the control arm bearings and rear subframe mounts when they hop up the suspension for track use.
leftcoast66 is offline   Reply With Quote
Old 02-26-2009, 02:15 PM   #5
herodcreekfarms
on what part of the spring do they go, mine dont have them and was just wondering if it was mandatry
Old 02-26-2009, 10:06 PM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
They are normally used to separate friction points. You will find the between the spring pack and the bottom "overload" leaf. Some spring sets have the pads between the longer top leaves as well.
Do you "need" them? Probably not, but you might get a squeaky spring if you don't have them.
Articles-
"Refining Sierra"
Old 02-26-2009, 11:54 PM   #7
herodcreekfarms
well i ask because i am getting my leaf spring powder coated so i figure these would help between the springs, to save the coating
Old 02-27-2009, 03:06 PM   #8
herodcreekfarms
is powdercoating the spring ok?
Old 02-27-2009, 07:53 PM   #9
N2TRUX
Happy to be here
N2TRUX's Avatar
I see no reason why not. The oven temps to bake the powder shouldn't be high enough to impact the spring tension.
Articles-
"Refining Sierra"
Old 03-02-2009, 01:29 PM   #10
jephs422
Not completely sure if this applies to leaf springs or not, but I know if you do a regular powder coat on coil springs....they turn stiff as heck!!
Jeff Savaglio
Scott's Hotrods
Oxnard CA 93030
jephs422 is offline   Reply With Quote
Old 03-02-2009, 04:11 PM   #11
N2TRUX
Happy to be here
N2TRUX's Avatar
Jeph- What's the alternative? I see them powder coated so is there is a low temp version?
Articles-
"Refining Sierra"
Old 03-02-2009, 06:24 PM   #12
jephs422
I believe so. I'll ask Justin. I know that whomever manufactures our springs for our coilovers for us (I should probably know that right, LOL) said there is some special way they powdercoat them
Jeff Savaglio
Scott's Hotrods
Oxnard CA 93030
