Old 02-27-2009, 08:51 PM   #1
skitzo42701
Unhappy '87 GMC Sierra, needs work but I'm broke...any suggestions?
Just bought this truck from my dad after my piece of **** ford got smashed by a tree (justice was served). Split window sticks, needs new interior, body work, paint job, and quite a bit of mechanical work too. It runs...but the belts are squalling like a long tailed cat in a room full of rockin' chairs, try to take off too fast and it hesitates and tries to die on ya. Wish I had the money to pour into it so that it would get the respect it deserves...but I don't. Therefore, if there's anyone out there that lives near Elizabethtown Kentucky...and willing to do a good deed (for DIRT CHEAP or FREE) just to help out a fellow Chevy/GMC Lover, Feel free to let me know!
skitzo42701 is offline   Reply With Quote
Old 02-27-2009, 09:05 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: '87 GMC Sierra, needs work but I'm broke...any suggestions?
Welcome to the forum skitzo42701. I'll give you the same advice I just offered Business Professor in aother thread. Start by making alist. Looks at what you "want" to fix/replace vs what "needs" to be fixed/replaced.
Make a "to do " list, and get back with us. We might be able to help you with advice, and that's something you can afford.
Oh by the way, we like pictures....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-27-2009, 10:22 PM   #3
kelsfine69
18 Till I Die
kelsfine69's Avatar
Yea fix what you need, someone told me a long time ago.." You cant drive looks" and he was right
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 02-27-2009, 10:30 PM   #4
72lb4x4
Tighten the belts to see if that works, or replace them.
Run some carb cleaner through it and/or put a kit on the carb.
Both are pretty cheap and worth the effort for a start.
72lb4x4 is offline   Reply With Quote
Old 02-28-2009, 12:30 AM   #5
66truckin
87 should be fuel injected. seafoam works well in fuel injection systems but I would trouble shoot what the real problem is first.
66truckin is offline   Reply With Quote
Old 02-27-2009, 11:21 PM   #6
flamingbig10
6.0 powered square
flamingbig10's Avatar
I agree to 72, and also check your vacuum lines, even if it doesn't sound like the problem
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 02-28-2009, 03:43 AM   #7
84 400
Sb 400 club
84 400's Avatar
Start with the basics like fuel pressure good plugs so on. Welcome to the forum lotta good people on here who can really help you out
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 02-28-2009, 04:19 AM   #8
79blazer
79blazer's Avatar
Confirm TBI or carb?
I would spend an afternoon going over it. Get to know it.
Check the plugs (gap and condition, color)
wires (resistance)
check cap
Adjust timing
look and listen for vacuum leaks,
check and tighten belts (they probably a little dry-rotted and cracked, a little cracked is ok, they seem to crack mid-life)
slipping belts can quickly break.
Check condition of all fluids, if old/dirty, keep in mind to change sometime soon.
Check brake pad wear, adjust rears. Bleed brakes.
Clean throttle blades and bores.
Check Pcv valve, clean or replace.
AFTER fixing problem, Adjust transmission linkage slightly if it shifts to hard/soft, early/late.
If carb a carb kit/carb dip will help it. Mine likes it every two years.
If TBI, clean IAC, rebuild/dip it. Problem might be caused by TPS or MAP. I'd post in the 88-98 forum for Engine stuff, because they have a lot more TBI motors.
Either fuel system, Berrymans B12 or Seafoam in the gas tank *might help,but won't fix the problem if it's something else. I am leery of most "magic" products, but these seem to be the only ones that work.
All of the stuff listed above are free or cheap, and may remedy you problem. They should be gone over once in a while anyway.
79 Blazer Cheyenne, 2wd 305 3.42 stock
85 Caprice, TBI converted, new 350 crate motor, Monte Carlo SS Wheels, Bilstein shocks,
79blazer is offline   Reply With Quote
Old 02-28-2009, 04:43 PM   #9
mainermikeyd
mainermikeyd's Avatar
Welcome to the forum for men with real trucks, like 79 blazer advised there are alot of things yo can do with out spending a dime, an there are some where you mite spend a couple dollars. Make sure to add some new fuel, LOF(lube, oil, filters) everyone else pretty much covered everything else, take your time inspect EVERYTHING, vaccum line especially, an if its affordable for you just for piece of mind get NEW plugs, I spent 2 weeks chasing a problem, that just came down to the simple spark plugs!!!! Good luck an keep us posted
Once a Marine Always a Marine OOH-RAH
GM Fanatic
1982 K20 4" Rancho lift 350cid, edelbrock performer intake 1405 carb, hedman headers, TH350, " Wheres the MUD!!!!!!!!!!"
1986 c30 camper special 454, th400 (for sale)
1984 K10 Big Ten (project) needs motor
1984 C10 355, 700r4, (project) needs shortbox bed
mainermikeyd is offline   Reply With Quote
Old 02-28-2009, 05:56 PM   #10
skitzo42701
All of that sounds like good advice...but as ashamed as I am to admit it, I know very little about working on vehicles.
Old 02-28-2009, 09:15 PM   #11
Restrorob
The One And Only !!!
Restrorob's Avatar
Welcome to the board first off !
Wouldn't you like to learn so you wouldn't have to pay others for minor repairs ?
Google is your friend, You can find all sorts of repair articles covering just about any repair. Here is one example;
http://www.autozone.com/shopping/repairGuide.htm
Also, You are a member here now. So should you get stuck understanding a certain repair all you have to do is shout, I'm sure someone would chime in to lend a hand.
Best of luck getting your GMC graciously motoring continuously again.
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 02-28-2009, 08:14 PM   #12
AceX
>130dB Moderator
AceX's Avatar
Take it one step at a time.
Start with something simple and then get slowly more complicated with the jobs.
Don't dive into an engine overhaul, just start with a few parts changes and go from there.
Living Life @ 130dB
LED Tail Light Conversion; How-to
Friend. Father. Brother.
RIP El Jay
CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum.
AceX is offline   Reply With Quote
Old 03-01-2009, 06:08 PM   #13
Damien
Damien's Avatar
Buy a Hanes Manual. They are cheap and will get you started. They show you how to do the simple stuff like change spart plugs. They have pictures and specs too. Check the stuff these guys suggested.
I can still count my vehicles on two... wait three hands.
Damien is offline   Reply With Quote
