Old 02-27-2009, 11:27 PM   #1
NuBomb
NuBomb's Avatar
Wheel Question
I need to find some wheels just to move my 51 out from the woods. I've got the originals and I got two of them to actually hold air. The other two simply can't do it.
What are my options. I just want something to turn my project into a roller. I'm looking for the easy/cheap way to get this thing moving.
Thanks, Jeremy.
Jeremy (NUBOMB)
72K5 CST 350/350/205
1951 Chevy 1/2 ton
North Georgia Group
"... And the first rule to being a man is you gotta spend your life doing crap you don't wanna do." Red Forman.
NuBomb is offline   Reply With Quote
Old 02-28-2009, 02:16 AM   #2
mr48chev
mr48chev's Avatar
Re: Wheel Question
If it is a half ton just about any of the pre 1988 six hole chev wheels should work as rollers.
Steel wheels with skinny tires will probably be the easiest to move it around on though. And yep the wheels or spare wheels off the K5 will work too.
If it is 8 lug just about the same thing goes.
Old 02-28-2009, 02:24 AM   #3
sgtusmc
sgtusmc's Avatar
Re: Wheel Question
Import 6 lug (toyota, nissan,) will also work. I used my stock 2007 tacoma wheels to move my 53 about 3 miles before the s10 swap.
My build, 53 GMC / S10 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=305723
My build, 59 Chevy / 88 fullsize swap
http://67-72chevytrucks.com/vboard/s...hlight=sgtusmc
U.S. Marines - Certified Counselors to the 72 Virgins Dating Club.
sgtusmc is offline   Reply With Quote
Old 02-28-2009, 10:51 AM   #4
NuBomb
NuBomb's Avatar
Re: Wheel Question
Thanks for the answers. That is exactly what I was looking for. I think the blazer tires may be a little too large unfortunatly. I'd hate to put a bend in the front fenders.
Jeremy (NUBOMB)
1951 Chevy 1/2 ton
North Georgia Group
Old 02-28-2009, 11:56 AM   #5
mr48chev
mr48chev's Avatar
Re: Wheel Question
If those are tube type tires you may be able to air them up with an air tank or 12V compressor. At least for long enough to get it out of the field and on a trailer. I've aired up tires with tubes that have been sitting for years and had them hold air, at least for as long as it takes to get the vehicle moved.
Old 02-28-2009, 05:44 PM   #6
NuBomb
NuBomb's Avatar
Re: Wheel Question
I got the rears to hold air, but the fronts I think were too far gone. I'm just going to find a couple of wheels and tires I can use to move it around a little.
Jeremy (NUBOMB)
1951 Chevy 1/2 ton
North Georgia Group
Old 02-28-2009, 08:09 PM   #7
B17CRX
B17CRX's Avatar
Re: Wheel Question
Why not take the two wheels off that won't hold air, throw some jack stands under it and pick up a couple free tires at a wrecking yard or maybe even your local tire store would give you a couple used tires then bolt em back up and you'll be good to go. Cheaper than buying wheels and tires just to roll it around.
-Joel
B17CRX is offline   Reply With Quote
Old 03-01-2009, 12:17 AM   #8
NuBomb
NuBomb's Avatar
Re: Wheel Question
I've tried that at a few places, but noone has any used tires that are narrow enough to fit on the rim. That is how easy I thought it would be, but doesn't seem to be the case.
Jeremy (NUBOMB)
1951 Chevy 1/2 ton
North Georgia Group
