Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 02-28-2009, 08:22 PM   #1
Sal's '55 Chevy
Sal's '55 Chevy's Avatar
Needing help on a 350
My brother is building a carb 350 for his 88 chevy truck, he is using a 88 350 block, bored 30 and decked, steel crank, flat top pistons, 5.7 rods, roller cam that has a 280 duration/525 lift, matching everything else to the cam, double roller chain, high volume pump, vortec heads with port and polish work,screw in studs and guide plates, not sure if he needs self align rocker arms or just aluminum rockers, rpm air gap vortec intake, msd dist with out vaccum, msd 6 box, holley 750 double pumper carb along with a electric pump and fuel regulator,and a set of headers. Do you change the valves in the vortecs and go with 202's or keep the 1.94 on vortecs? What do you guys think about this build any suggestions,changes or ideas? What horsepower should it make?
'55 Chevy PU 2nd Series
'97 Chevy Silverado XCab
'13 GMC Sierra
Sal's '55 Chevy is offline   Reply With Quote
Old 03-01-2009, 11:30 PM   #2
americanmusc1e
americanmusc1e's Avatar
Re: Needing help on a 350
You are not supposed to use guide plates and self-aligning rocker arms together, use one or the other. you don't get much added airflow from changing the 1.94 to 2.02 valves. if you want more flow it is probably almost as cheap to go to aluminum heads
-- Josh
Instagram: @americanmusc1e
OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread
FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread
1999 4wd OBS Tahoe - daily.
DM me if you can't see photos i posted
americanmusc1e is offline   Reply With Quote
