Old 03-01-2009, 01:01 AM   #1
GREASEMONKEY72
GREASEMONKEY72's Avatar
engine sputter after rinsing
i used to always be able to rinse my engine off with out any problems till the last 3 times ive done it
the first of the 3 it wouldnt start unless i held the choke plate open and then it would sputter everytime you touched the pedal
then these last 2 times it starts fine but will sputter if you touch the pedal and it even died out while i was moving it around on the lawn the time before last and even backfired through the carb
i pulled the carb off and made sure the screws were tight and made sure its tight to the intake, checked and made sure the intake bolts were all tight and the manifold bolts aswell
any ideas???
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 03-01-2009, 01:08 AM   #2
Matt's k5
BLAZER THIRTY!!
Matt's k5's Avatar
Re: engine sputter after rinsing
water in the distributer cap will cause crossfire to other cylinders and back fire though carb
49 chevy 5 window 20 year project (sold)😟
57 ford fairlane (dad's car never got to it before he passed away R.I.P I LOVE YOU DAD.)
62 GMC 305 V6 custom L/B
72 HIGHLANDER K5 BLAZER 2nd owner
71 K5 MAMMA'S RIDE!
63 GMC 4X4 305 V6
62 GMC SHORT BED SERVICE BODY V6 (STUMPY)
74 GMC CUSTOM 1500 L/B
Matt's k5 is offline   Reply With Quote
Old 03-01-2009, 01:11 AM   #3
GREASEMONKEY72
never thought of that, ill have to check that out tomorrow in the daylight
-steven
Alte Seele S.S.
Old 03-01-2009, 02:04 AM   #4
enaberif
I take it you're washing your engine bay?
Should always cover up the alternator and distributor with a plastic bag to make sure no water gets into these spots.
enaberif is offline   Reply With Quote
Old 03-01-2009, 02:08 AM   #5
bigbadchev72
People know me
bigbadchev72's Avatar
spray the inside of your cap with wd-40 if you do find water
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels
1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels
bigbadchev72 is offline   Reply With Quote
Old 03-01-2009, 10:09 AM   #6
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
The letters WD stand for Water Displacer.
Another thing to use is toilet paper. Use it to daub away any moisture that gets into the cap.
Next time, get a plastic freezer bag and place it over the top of the distributor cap/wires. You can take a Cool Whip container, make a hole in the center of the bottom of it and slide it down over the air cleaner stud and bolt it down to keep water out of the carb.
Member Nr. 2770
Old 03-01-2009, 10:26 AM   #7
68gmsee
Active Member
68gmsee's Avatar
One more thing to check:
Wait till dark and spray the spark plug wires and cap with a fine mist from a bottle spayer. Start the engine and check for crossfiring. I had couple of vehicles do the same thing. One was water condensing inside the distributor cap and the other was old spark plug wires. (If your spark plug wires are fairly new disregard this).
68gmsee is offline   Reply With Quote
Old 03-01-2009, 10:29 AM   #8
68gmsee
Active Member
68gmsee's Avatar
msgross beat me to my suggestion....
But forgot to mention that on my distributor cap condensing problem, it happened even after a heavy rain storm. I used silicone to seal the bottom of the cap where it rested on the housing. Not recommending this, but it solved my problem.
Old 03-01-2009, 10:33 AM   #9
gumbudah
As others have mentioned I'd spray water on the plugs/wires/cap, but I'd also start with the engine cold, and spray one at a time starting with the lowest parts working upward, that way you won't spray everyting all at once and not know which part is causing the problem.
gumbudah is offline   Reply With Quote
Old 03-01-2009, 02:30 AM   #10
72blue
72blue's Avatar
x2. let us know if that doesn't work
72blue is offline   Reply With Quote
Old 03-01-2009, 10:20 AM   #11
msgross
msgross's Avatar
sputtering after a car wash or rain is almost always electrical as stated... You could also do a test to see if you can find a short... At night start your engine, open the hood and take a squirt bottle with water in it to the engine... If it sputter when you hit something (wires, distributor, coil, wiring harness etc..) then you found the weak spot. This is another good way to check for small arcs (lighting bolts) where your wires could be shorting out...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 03-01-2009, 10:28 AM   #12
msgross
msgross's Avatar
must be an echo in here
The Garage:
Old 03-01-2009, 10:52 AM   #13
Sinister
Between Trucks...
Sinister's Avatar
I had this problem after having my motor pressure washed. Tried WD-40, ended up swapping the points dizzy to an HEI.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 03-03-2009, 04:28 AM   #14
GREASEMONKEY72
well it was water in the cap, i dont know why i never thought of it before, however it did take over 3 1/2 years to cause a problem
there was some oxidation inside the cap which i sanded most of it away with some emery cloth and now it runs and starts a bit better
gona look into just replacing the cap and rotor anyway and either new points or a points eliminator
any recommendations on a good points eliminator?
-steven
Alte Seele S.S.
Old 03-03-2009, 11:33 AM   #15
monte0185
monte0185's Avatar
Buy an HEI distributor off ebay. Theres a guy on there selling them pretty cheap. Someone will chime in with his name. I cant remember it off the top of my head.
A computer once beat me at chess, but it was no match for me at kick boxing.
Duct tape is like the force. It has a light side, a dark side, and it holds the world together.
monte0185 is offline   Reply With Quote
Old 03-03-2009, 03:19 PM   #16
dznucks
dznucks's Avatar
skip white is his name. i think its whitesperformance1 is his store name or skipwhitesperformance1. something like that. i have one. its a decent dizzy for the money.
dznucks is offline   Reply With Quote
Old 03-04-2009, 12:11 AM   #17
GREASEMONKEY72
i dont want to switch to hei, i like the points setup with the external coil and smaller dizzy
i was wondering if theres any preferences on which points eliminator is better than the other?
-steven
Alte Seele S.S.
