03-01-2009, 06:12 PM | #1 |
Prostreet 72
LS1 or traditional SBC
I need advise. I have a line on a 6.0L LS1 engine. The price is right. I would make the switch to a carb if I go this way. Can anyone tell me what I need to get with the engine to make it work for me. I will be using a TH350 trans.
Also, can anyone tell me the pros and cons of making the switch? I can build a bullet proof big inch big block, but these new fangled things are just that, new fangled things to me. Chris P.S. This is going in the "Green Monster" build.
Prostreet 72 "Green Monster" 1972 Fleetside Build http://67-72chevytrucks.com/vboard/s...1&goto=newpost http://67-72chevytrucks.com/vboard/s...d.php?t=319041 |
03-01-2009, 07:09 PM | #2 |
Eat My Rust
Re: LS1 or traditional SBC
The LS motors are a pretty simple motor to deal with once you decide to go with a carb and get rid off all the sensors need to run the fuel injection.
I'd go with a Carb'd LS1. Just about 400 hp right out of the box and the odd-ball carb'd late model motor. |
03-01-2009, 07:37 PM | #3 |
5.7L LS1 or 6.0L LS2 or LQ4
which one are you talking about i'm thinking about doing a LQ4 swap into my truck, the motor and tranny together go for about $1500 an LS1 or LS2 and tranny will cost you around $5000 easy the reason i am going with an LS series is they take more HP on factory cast bottom ends although speed parts are more expensive for them genIII smallblock (LQ series iron truck motors) cast bottom ends can handle about 700HP on stock bottom end without too much trouble genI smallblocks (350 etc..)will take about 500HP on a stock cast bottom end
-- Josh Instagram: @americanmusc1e OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread 1999 4wd OBS Tahoe - daily. DM me if you can't see photos i posted |
03-01-2009, 09:04 PM | #4 |
I'm not sure for your reasoning for eliminating the fuel injection/ computer control of the motor, but I will provide my personal experience & opinion. After putting a 5.3 with injection in my truck, i'll never go back to a carbed motor. Runs like a champ & I averaged just over 20MPG overall on the 08 "Power Tour".
The kid Build threads: 51 Jimmy http://67-72chevytrucks.com/vboard/s...d.php?t=154951 http://67-72chevytrucks.com/vboard/s...d.php?t=219902 http://www.classictrucks.com/feature...uck/index.html 68 C10 http://67-72chevytrucks.com/vboard/s...ad.php?t=50348 |
03-01-2009, 10:44 PM | #5 | |
03-01-2009, 10:59 PM | #6 |
Moderator
Prostreet, the 6.0 is a great engine whether you stay FI or go carb. It's your choice, don't let anybody tell you different. FI offers great performance, tunability, driveability, and mpg. It's not that difficult, you just need somebody to do your tuning. Carb conversion is simple and effective.
For the carb conversion you will need: MSD 6010 ignition controller and harness (people don't like the Edelbrock version because it's timing is not programmable and it has too much). GMPP or Edelbrock (performer or victor jr) LSx intake for carb 6-7 psi / 110gph fuel pump and regulator Flexplate adapter/spacer for TH350 Exhaust manifolds - S&P, Doug Thorley headers or 98 f-body stockers. I am going to use '04 GTO manifolds. Check out the "conversions & hybrids" section on ls1tech.com.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
03-01-2009, 11:09 PM | #7 | |
Thread Killer!
I bought HPTuners to do all my own tuning but there are lots of guys that can do it all for you. Good luck either way!
71 Cheyenne SWB LS1 and auto. http://67-72chevytrucks.com/vboard/s...d.php?t=256470 _____________________________________ If it's worth doing, it's worth doing twice... _____________________________________ Don't Mistake Honesty for Negativity... |
03-03-2009, 07:01 PM | #8 |
I used a custom harness built by "Speartech" & am very happy with it. Top notch quality wire /terminals/protective wrap. John uses "hi-temp" wire loom & asbestos wrap where needed.
03-01-2009, 09:08 PM | #9 |
If you go carb, you will also need a way to run the ignition....edelbrock and MSD have solutions.
Not too sure how the TH350 works....seems I read somewhere you may need a flexplate adapter or.....? Sure someone will pipe in on this.
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - My Build Thread |
03-01-2009, 10:41 PM | #10 |
Thread Killer!
Not sure why you would want to get rid of the FI, but they are great motors, I only have a couple of miles on mine and I will never do a carb again, I love it.
03-01-2009, 11:13 PM | #11 |
If your going to switch to a carb, why bother with the 6.0L? I'm going to assume you all ready have a SBC in the truck? Why not just spend the money on improving it instead. Plus, it will cost you more to switch to a carb than just leaving it injected, even if you have to buy a harness and PCM seperately. Don't be scared of these motors. Once you get down to the basics, a motors a motor, whether from 2009 or 1960.
My .02 I can get you PCM pinouts if you decide to go that route and modify a stock harness, cheapest and pretty easy. Just let me know.
1971 Suburban 4x4, LQ4 6.0L, 4L80E, etc. Last edited by boostat4500; 03-01-2009 at 11:16 PM. |
03-01-2009, 11:26 PM | #12 |
Eat My Rust
03-01-2009, 11:59 PM | #13 |
Well i was torn with the same thing then i read an article in a performance magazine and read about the motownLS it is an old school block adapted to run ls heads the best of both worlds!!!! But if you go with the 6.0 liter go with the lQ9 not the LQ4!!! The LQ9 has aluminum heads !!! This is the same motor i have in my Silverado SS The best time was a 14.3 at 94 mph So in know that ,that truck would run even better cause it isnt near the weight of my SS!!! Good luck with the choice!!!
Ernest B.
1968 GMC Rebuilding Stage 2001 Camaro SS SOLD |
03-02-2009, 12:14 AM | #14 |
Actually, other than the very earliest LQ4's they both have aluminum heads. The difference between the LQ4 and LQ9 is the pistons. The LQ9 has flat tops and about a half point higher compression. Heads are identical.
And I agree that the motor is still better than a gen 1 even with a carb. I just don't understand dickin' with the swap if your not going to keep it's biggest advantage, the EFI.
1971 Suburban 4x4, LQ4 6.0L, 4L80E, etc. Last edited by boostat4500; 03-02-2009 at 12:14 AM. |
03-02-2009, 12:35 AM | #15 |
Agreed!!!! Good call on the LQ9 and LQ4 I thought that the heads were different!!!!! Learn something new everyday!!!
03-02-2009, 01:08 AM | #16 |
Im planning on going the LS route with a carb...alot of people dont like the efi garbage IMHO so please dont flame me...For me its alot easier to adjust my holley double pumper with a screwdriver then cranking up my laptop to adjust anything.And the tested the carb vs efi on the LS familt of engines not to long ago...They held almost identicle numbers for power but it had more low end grunt to it with the carb and put out a good more torque with the gmpp manifold and a 750 holley atop the block
"Dixie Destroyer" 71 C10 LWB Fleet Future Blown Prostreet Monster |
03-02-2009, 01:18 AM | #17 |
That's the point...with EFI you don't have to adjust a thing once the initial tune is done. That said I ain't here to talk anyone out of a carb. It took me the last ten years to come around to even thinking about a new gen motor. Now that I am here though, I'll NEVER pay to rebuild another gen 1 motor and I can't wait to ditch carbs forever.
With me it's all about getting 325-350horses WITHOUT stopping at every other gas station. Not toi mention starying effortlessly EVERY morning regardless of the temps outside. Go with the LS motor, even if you insist on a carb. I doubt very seriously you'll be disappointed.
Kelly '05 GMC Sierra SLE Z71 Bone stock except for new bed rail caps. Last edited by Gray Ghost; 03-02-2009 at 01:19 AM. |
03-02-2009, 01:57 AM | #18 |
x2 gray..The way to swap the cam in the LS is pretty trick aswell and real easy
03-02-2009, 02:13 PM | #19 |
Gen III engines are great, and I've never had a problem with them. I've had 6 of them.
I think the big advantage of them is the fuel injection. You get all that power without hurting the wallet (gas $$$). In my corvette I have gotten 33mpg!!! And it ran a 12.18!!! Plus, tuning with a laptop, you don't get your hands dirty |
03-02-2009, 04:52 PM | #20 |
Yeah, another vote for the fuel injection, also thumbs up on the motown ls1 old school block. If I was crapping out cash, I would build one of those.
03-02-2009, 05:19 PM | #21 |
If you want to drop an LS Gen III motor into your old truck, why not upgrade the transmission too? Why keep the old 3-speed Turbo 350 when you can get a newer auto tranny 4L60E or 4L80E that has overdrive and is designed to work with your LS engine. Makes more sense.
"Two rules get you through life: If it's stuck and it's not supposed to be, WD-40 it. If it's not stuck and it's supposed to be, duct tape it." |
03-02-2009, 05:45 PM | #22 | |
Prostreet 72
I will probably go with the carb over the fuel injection because I like carbs. I like how they look on these engines, and how they run on them. My trucks are not driven everyday. In fact, the black truck has not been wet, via a hose or rain drop in three years. So fuel economy is not my primary goal. I would just like to step up to something new. Learn something new for the future.From what I have been told by some builders, the stock LS1 with a carb swap will make 375-390hp out of the box. To take my tired old 350 andrebuild it to the same hp, I will spend more than I am on this new engine. Right now I can't expose my engine source, but after it is on my garage floor, I'll give you all his name and phone number. This engine is coming with a spun bearing. Thus the low price. I still can't believe it myself. There are many, many more where this one is coming from. I will let you in in the source later. I appreciate all of the help and guidance with my LS1 swap. You guys are the experts, having been there already. I may not go in the exact direction you went in, but still the same require your help with my swap. Thanks a ton! Chris
03-02-2009, 06:08 PM | #23 | |
I have a radical idea!
I was posted while you were. I totally understand the kids and bills thing. If you go with the LS1 now you can always upgrade to OD and EFI later. If you getting a great deal, I say go for it. Most people who have them around here are way too proud of them.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! Last edited by 67_C-30; 03-02-2009 at 06:09 PM. |
03-02-2009, 06:11 PM | #24 |
When you get your engine, please put in line for the PM list of your source. I'd love to buy one that just needed a crank or something. I wanna tear into to one anyway!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! Last edited by 67_C-30; 03-02-2009 at 06:12 PM. |
03-02-2009, 08:16 PM | #25 |
Happy to be here
Yeah, that's true. But if you keep the efi and do a cam/heads swap you can run 500/hp with the a/c on.
