Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 03-02-2009, 12:11 AM   #1
85_prairieboy
85_prairieboy's Avatar
Mounting a fuel cell
I have a few questions about mounting a fuel cell. Should I be mounting it in the bed or below the bed? I would like to put it in the right spot for weight transfer the first time. It won't be hauling anything in the future. When I make my retaining straps should I insulate them with rubber to protect the aluminum tank? What do you use for a vent on the tank? I was thinking of running a hose from the rollover valve to an inline fuel filter.
85 GMC toy Lowered, newer box swap, 350 .060 over with AFR 195s, forged pistons, TCI TH350
1.83 60' 13.14 @ 100 on motor
1.49 60' 11.52 @ 116 w/150 shot
1952 Chevy truck project
1980 Z28 Camaro
1967 Camaro drag car 10.60@126
85_prairieboy is offline   Reply With Quote
Old 03-02-2009, 12:41 AM   #2
71Dragtruck
71Dragtruck's Avatar
Re: Mounting a fuel cell
In bed aluminum tanks don't use straps, they have tabs. As for under bed tank if it has a strap system I would use rubber insulators.
Speed is just a matter of money, question is how fast can you afford to go?
8.95@148.97mph all motor haven't tried bottle yet
Sponsored by:
Getz Oilfield Consulting
Hard Candy Customs
71Dragtruck is offline   Reply With Quote
Old 03-02-2009, 12:48 AM   #3
85_prairieboy
Hey that is the same tank I have! There was a note attached to mine saying to only use those tabs for locating but obviously they serve the purpose for yours. BTW how did you vent your tank?
1980 Z28 Camaro
Old 03-02-2009, 01:33 AM   #4
71Dragtruck
The line on my battery side with the coil in it is the vent line, it is open ended under the bed.
Sponsored by:
Hard Candy Customs
Old 03-02-2009, 11:29 AM   #5
Marv D
Registered Truck Offender
Marv D's Avatar
Like you mentioned, a small filter at the end of the vent line will keep dust, debris and especially critters out of the line. Here we have a species of bee that gathers bogenvia flowers and packs them into every dam open tube they can find!!!
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 03-02-2009, 01:46 PM   #6
Wild83C10
Wild83C10's Avatar
It looks like I have the same cell as 71Dragtruck. I have it mounted in the same location but on top of aluminum tubing. This way I didn't have to cut a large hole in the floor for the sump.
I have the vent line coming from the same port. Mine goes to a filter then to a charcol canister.
No need to use straps or rubber mounting isolators.
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
Old 03-02-2009, 02:07 PM   #7
85_prairieboy
Thanks guys. That helps a lot. I can't wait to post some timeslips. I've been trying to get this thing to the track for 2 years now and am now finally getting the little odds and ends together
1980 Z28 Camaro
