03-02-2009, 10:40 AM | #1 |
Jason
Trailing Arm Wheel Hop
I just got finished installing mini spool and 3.73 gear. Now have bad wheel hop. I have the rear lowered 4.5" with 3" coil and 1.5" drop block. The shocks are still located in original location as well as the track bar. Would relocating the shock mounts with a better shock possibly fix problem?
03-02-2009, 10:53 AM | #2 |
Re: Trailing Arm Wheel Hop
you really do need to get droped shocks and relocate. I would also get an adjustable trac bar. that is your biggest prob. If orig trac bar and not adjustable it is pushing your rear over more then it needs to be. your geometry changed with the drop.
69 c-10 BBC 462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build. |
03-02-2009, 11:33 AM | #3 |
Jason
As djracer stated I have adjustable track bar in stock location, but shocks are standard length and are in stock location. I was just wondering if getting the shock relocation kit would fix problem or if it could maybe possibly be the pinion angle causing problem?
03-02-2009, 11:23 AM | #4 |
He has an adjustable panhard bar but its in the stock location.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
03-02-2009, 01:08 PM | #5 |
Have you checked your pinion angle? Perhaps there is some binding that might be causing the wheel hop?
83 C10 Stepside (SOLD, it was a blast!) 383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt S475 and C4 DM running, fine tuning turbo= Douchebag Racing: Runs Fine all the Time |
03-02-2009, 01:24 PM | #6 |
Jason
I am not sure on the exact pinion angle. I will have to check to see. The only other thing is that when drive shaft is installed it only has about a 0.25" or so until the yoke bottoms out on output shaft. I would not think that would be a problem with wheel hop though.
03-02-2009, 01:46 PM | #7 |
I'm running:
Stock Arms Comp 3-way adjustable in the rear in the factory location (probably going to swap this out very soon) A early 90's Jeep Cherokee front spring that I had to cut (probably going to swap this out very soon) 2" block I have not experienced wheel hop. Too heavy of a spring, too loose of a shock, wrong pinion angle, binding sway bar due to the rear being shifted.. All of these could have an effect, so the more info we have, the better help we can be. I'm with Wild83.. You can get an angle guage at any hardware store. Here is a write up from CarCraft on the subject of checking it. http://www.carcraft.com/howto/91758/index.html Did you lower the vehicle before/after or during the minispool swap? When lowering, who's spring did you use? Any chance you can get a measurement of the coil diameter (preferably with a caliper). Are you on stock shocks? Do you have a rear sway bar? As far as the Panhard bar being the culprit, I kind of doubt it. Yes there would be rear shift due to the geometry change (unless you fixed that already being you have an adjustable). The only way I could see it being an issue is if it was putting the suspension in to a bind do to the rear being sooo far to one side. The later trucks if I'm right have a shorter PH bar than my truck. So I guess it's possible, but I'm guessing it would have to move it really far to one side.
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 Last edited by Super73; 03-02-2009 at 01:51 PM. |
03-02-2009, 03:07 PM | #8 |
Jason
I will pick up a angle gauge after work to check the exact angle. I have no sway bar front or rear. The springs are classic performance as well as blocks. I installed the drop a couple of years ago and yes it has stock replacement shocks. The only thing I changed at the time was the gears and minispool. It had a open diff and 3.07 gear before. When I intalled the panhard bar I made sure the axle was centered.
03-02-2009, 03:26 PM | #9 |
Did you change tire too? If so from what to what..
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
03-02-2009, 03:35 PM | #10 |
Jason
No still on the same tires. 275/60/15 radial on 15x8" aluminum wheel. I will install a drag radial of some sort eventually. I just have to fix this problem first.
03-02-2009, 03:38 PM | #11 |
Jason
Owe yea I went home at lunch and made a visual on the angle of the pinion. It is already rotated up towards the bed so when under power it would rotate even further right?
03-02-2009, 04:02 PM | #12 |
Depends on if you are squating the rear or not. If the rear squats, then no, pinion would face further down, if it is seperates, pinion would rotate up. By my math it's about 1* per 1" of movement. There is very little pinion wrap due to the suspension design (Being like a ladder bar). Perhaps a little from the factory bushing and the arm might bend a touch.
As far as a visual, remember, the trans needs to be pointing down with the same angle the pinion is pointing up to have 0* pinion angle. From that point, if the rear is up say 2* then you have +2* pinion angle. If it's still pointing up, but it is 2* bellow the trans plane, then you have -2* pinion angle.
03-02-2009, 04:16 PM | #13 |
Jason
Thanks alot for the info Super73. I will check out the pinion angle and let you guys no what I find out. In the mean time I will also be relocating the shock mounts,and installing some sort of a different type of shock any recommendations?
03-02-2009, 08:10 PM | #14 |
I have that problem also with 3.73 and mini spool on a 295-50-15 but when I had my 4.56\moroso unit(BOOM) I had no problems. It met it fate coming off the highway when crosspin bolt came out and Kind of locked things up.
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
03-05-2009, 09:15 AM | #15 |
I'm not sure how a trailing arm rear end could experience wheel hop unless the front bushings are really worn or it has a spool and is making a turn. Are you talking about going around corners ( driving normal) when you have wheel hop?
If yes, there isn't anything you can do unless you install a posi unit. Is one tire worn much more than the other making it "smaller" than it's mate on the other side? I guess that would do it as well with a spool... Just a thought...
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners. Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=219094 Last edited by whatnow123; 03-05-2009 at 09:18 AM. |
03-05-2009, 10:54 AM | #16 |
He ordered some rancho 9000 adjustable shocks yersterday as he did have some issues with the rear shocks. We will let you guys know if they solve the problem.
03-05-2009, 01:36 PM | #17 |
Little soft?
03-05-2009, 02:02 PM | #18 |
A little worn out and 1 bushing was almost gone.
03-05-2009, 02:06 PM | #19 |
Jason
Alot soft. I rechecked my axle to make sure it was centered and the pinion angle is good. So maybe the shocks will help.
03-05-2009, 02:22 PM | #20 |
Jason
Whatnow123 it wheel hops when eccessive wheel spin occurs. I played with air pressure and it was much better but would still do it on occasion. I think it is just the rear shocks being worn out causing problem but we will see.
03-05-2009, 05:11 PM | #21 |
It needs some drag radials so it won't spin then no hop.
03-24-2009, 01:49 PM | #22 |
Jason
Just updating about the wheel hop situation. I replaced the rear shocks, and the trailing arm bushings. It will still hop a little when the radial tires begin to hook up. I put on some M/T ET streets and went to the local drag strip and had no issues with hop with these tires installed. I guess it is something to do with the radial tires.
