Old 03-02-2009, 11:10 PM   #1
79gmcsierragrande
Manual Transmission Club
79gmcsierragrande's Avatar
Fuel pump question
I was under the hood with it running and there was gas coming out of the fuel pump. So I went to Napa got a new fuel pump. I replaced both gaskets and made sure the rod was put back in the right way. The truck sputters like it’s running out of gas when it’s idling but not all the time. It runs good and doesn’t hesitate when I step on the gas while I’m moving. This morning I got stuck in an intersection when the truck died out and wouldn’t start as if I ran out of gas. It was running fine before the pump change so I’m thinking it’s a bad pump but is there anything I should check or adjust before I take the pump back to Napa?
79 GMC Sierra Grande, SWB, Heavy Half
If I wanted easy I would just buy a NEW truck!
79gmcsierragrande is offline   Reply With Quote
Old 03-02-2009, 11:50 PM   #2
f.monroe
f.monroe's Avatar
Re: Fuel pump question
You might disconnect the discharge from the pump and measure the cranking flow rate . It might be putting out very little . Other than that , where is the fuel filter ? In carb ? If so , you might change it .
Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 03-03-2009, 08:03 AM   #3
dga93
newbie
dga93's Avatar
This is what happened to me the other day and i had to change the hose from the fuel pump the the filter.
dga93 is offline   Reply With Quote
Old 03-04-2009, 02:19 AM   #4
79gmcsierragrande
I thought fuel filter too, I bought it yesturday and put it in today but no change.
I'll try measuring the flow tomorrow it's too late tonight.
I guess it wouldn't hurt to change the fuel lines but I don't see that helping, not sure...
Old 03-16-2009, 10:59 PM   #5
nvr_di
nvr_di's Avatar
79gmcsierragrande did you figure this out? Mines doing the same thing
nvr_di is offline   Reply With Quote
