03-04-2009, 01:07 AM | #1 |
Repo Tachs
I used the search to no avail.
Is there different quality of repo tachs? If so who has the best? Thanks Ron
Member #111 68 C-10 Daily Driver 70 4x4 Project 76 Jeep CJ-5 Help Support the Board: http://67-72chevytrucks.com/vboard/payments.php He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors. Thomas Jefferson |
03-04-2009, 06:24 PM | #2 |
Re: Repo Tachs
Anyone?
Who sells the Best quality reproduction tachs? Thanks Ron
03-04-2009, 07:36 PM | #3 |
Re: Repo Tachs
The one I bought from LMC works fine. They come 8 cylinder only, so I had to have it recalibrated for my V-6.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90. Last edited by Bob B.; 03-04-2009 at 07:37 PM. |
03-04-2009, 07:39 PM | #4 |
Grandpa in the rustmobile...
Re: Repo Tachs
will it work in the 3 hole instrument bezel, are they hard to install wat do they run thanks
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
03-04-2009, 08:56 PM | #5 |
Re: Repo Tachs
I thought I had seen on here that all the tachs out there are not of the same Quality but when I searched I had no luck. That is the reason I asked the question.
As far as price just the tach is about $90.00. They can be made to fit in a 3 hole dash I htink(I have never done) but they are for a full guage set up. If you were wanting a factory tach you should just keep an eye out for a full setup on the parts board. It would be cheaper than pieceing a setup together. Ron
03-04-2009, 10:19 PM | #6 |
Re: Repo Tachs
here's a pic for you.I not a subscribing-paying user , but I have it on ebay right now, after it sells I'll pay up, so hopefully this won't cause any riffs with anyone.
110358493799 item # |
03-04-2009, 10:55 PM | #7 |
Re: Repo Tachs
I bought one from Brother's - they slash the price on them from time to time. They aren't very accurate, but they do look factory, and if you're not real performance oriented, they work just fine.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD Click here to support the board Philippians 4: 6-7 |
03-04-2009, 11:17 PM | #8 |
Re: Repo Tachs
I debated about factory vs aftermarket for a long time. I finally went aftermarket but tried to find one that did not stand out too bad. this is what I ended up with-
1970 K20, 350--- SOLD 05 silverado extended cab short box- duramax Jeep wrangler unlimited |
03-05-2009, 01:14 AM | #9 |
Old member
Re: Repo Tachs
Ace in the hole,
Can you give out some info on your tach? What brand is it and where did you find it? I have a couple of old dashes I need to redo.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
03-05-2009, 08:16 AM | #10 | |
Re: Repo Tachs
Installed very easily, I took a hole saw and cut the plastic lens out, cut the front tin plate and the back tin plate. Then assembled it all and cut the printed circuit board where I needed to. The gauge mounts so simple right to the front bezel with a plastic screw on ring. As for wiring it, you need power, ground and the signal connections along with the dash light connections. I am going to tap off the ground screw for all the grounds, off the temperature gauge feed screw for power (need to figure out which side) and run a lead from my hei dist. for the signal. You can also use a signal from a alternator lead. The lights I will just tap into the wire for the dash lights on the harness. You end up cutting one line of the circuit board but it's just the ground line. I cleared the plastic off and re grounded the one side with the screw you see in the pic
1970 K20, 350--- SOLD 05 silverado extended cab short box- duramax Jeep wrangler unlimited Last edited by Ace in the hole; 03-05-2009 at 08:19 AM. |
03-05-2009, 07:41 AM | #11 |
Re: Repo Tachs
Installed a marine tach in my dash panel
'71 GMC;fleetside;PB/PS/AC/CC/402 Eng./Custom Paint/110,000act miles/3 fuel tanks(52gal). |
