Old 03-04-2009, 12:45 PM   #1
rddaves54
rddaves54's Avatar
exhaust manifold bolts
I need exhaust manifold bolts for the head. I bought new manifolds and the old bolts are worn out and rusted away. I went to Chevy dealer they only carry metric. I went to Lowes but was wondering if their bolts would be strong enough? Can anyone tell me where I can get a set for my 350 72 engine? Saw one set on E-bay.
What size washer goes on the bolt to the harmonic balancer? I believe mine has the washer for the big block because it goes over the hole and not into the hole.
rddaves54 is offline   Reply With Quote
Old 03-04-2009, 03:18 PM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: exhaust manifold bolts
www.truckandcarshop.com has the correct manifold bolts. check with a vendor here also, as they might have them as well.
I also used some grade 8 bolts from home depot a few yrs back, and they have held up just fine.
Old 03-04-2009, 03:33 PM   #3
haysonj
haysonj's Avatar
Jegs sells any bolt set you might need.
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 03-04-2009, 05:00 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
any grade 5 or better bolt will do. They aren't anything special. Put antiseize compound on them before you install them for the next guy.
Old 03-04-2009, 05:09 PM   #5
cdowns
cdowns's Avatar
if you want a washer that fits into the harmonic balancer why not just use a ruler and measure the diameter of the hole you want the washer to go into?
Old 03-04-2009, 05:25 PM   #6
Wrenchbender Ret
Most Ace hardware stores have a good selection. I use grade 8 bolts on manifolds & practically everything else. They are identified by 6 lines on the head. The damper washer is a special washer. It has a 7/16 bolt hole & is extra thick. The dealer should have it or the salvage lot.
Wrenchbender Ret is offline   Reply With Quote
Old 03-04-2009, 08:35 PM   #7
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I always use normal old grade 8 3/8 inch bolts for my manifolds. Tractor Supply sells them by the pound.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
