bolt on dual exhaust system
I found on LMC web sight a “complete V8 high performance dual exhaust system with bolt on convenience” for $250 I had a price quote for $375 from a muffle shop. It comes with turbo mufflers and all the pipes and hangers.
I was wondering if any of you had put one on from LMC and what you thought. I was thinking it looks good and had everything necessary to bolt right up. |
Re: bolt on dual exhaust system
it's a good system only thing is the diagram isnt much help so its just a matter of you figuering out what goes where// butr once installed it fits good and lasted good
I got the Hooker bolt on from Summit. Twice.
The first one was for my 76 Blazer and it worked great. Bolted right up with minimum problems. The second was for my 71 C20 and it didn't fit very well. I ended up taking it to a muffler shop anyway, just to make one side fit. The other fit great. I don't know about the LMC ones, but I think the DIY exhaust is ok if you don't mind spending the time instead of the money.
Curry in a Hurry: SB rebuild for my 71 C20 |
#4 | |
69 Chevy 4x4 383 Power ![]() |
I would only want a welded system.I`d weld the LMC or any other ready-made pipes.But,I prefer custom,personally.
I am not using headers will that make a difference? Stock manifolds.
The LMC kit is drop shipped from a company in Minnesota called Heartthrob Exhaust.
I believe they sell kits for headers or stock manifolds. Make sure you order the correct kit for you application. I ordered the 4x4 dual kit from LMC for my K10. Everything was included in the kit from the new donuts for the manifolds all the way back. I did end up going to NAPA to get a different hanger for the side that didn't have a factory hanger. If your truck was a factory dual truck you won't need to do that. Unlike special-K and Andy4639 I'm in the clamp verses weld camp. I'd rather not deal with a weld when replacing just a muffler. In the last year or two I had to replace my mufflers on my Heartthrob kit. That is not to say I don't see the value in a fully welded system. I just like cutting clamps and removing components. Here in Minnesota any small leaks around a clamped joint rust shut in about 90 milleseconds anyways. ![]()
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
#8 | |
resident oilfield trash
1967 SWB C10 396/400 factory air factory tach (sadly had to send to a new home) 1986 Honda 70 Fourtrax 1991 Chevrolet K5 blazer 2wd 1982 Mastercraft Pro Star 190 Stars and Stripes 2002 Chevrolet Tahoe 2011 Nissan Armada ![]() |
#9 | |
I have had the opportunity to work on vehicles from dry climates. Things like exhaust manifold nuts actually back off the studs - without twisting off the stud. Mufflers actually last 10 years. Y-pipes last for almost the life of the vehicle. Not here. I have owned cars since 1984 and have never got 10 years out of a muffler. Performance, cheap, or in between. ALL mufflers, regardless of where you live rust from the inside out. In climates where there is moisture in the air like here they are also rusting from the outside in. Perhaps clamps look cheap but if you need to replace components they are the only way to go. All you 2wd guys that are lowering your trucks - I don't know how you'd see the clamps anyways. One way to clean things up under there is to turn the clamps so the bolts point UP. Form follows function.
Old member
At $125.00 more I think it would be worth the extra money for them to do it. Juct my .02!
Plus it would be all welded and less likely to leak.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#12 | |
![]() Join Date: Jan 2008
71 cheyenne lwb 300rwhp best 1/4 time so far 12.8 @103 ![]() http://i195.photobucket.com/albums/z...en58/001-2.jpg |
425hp409
![]() Join Date: Oct 2008
I bought the LMC kit thinking I could install it at home in my "Home Shop". WRONG.....I had to trailer the truck to my Automotive Shop and cut and bend it to fit, it was a royal pain in the ---. Once installed, it looks great.
Charles |
You should still be able to order a complete exhaust system through some parts houses. It may take a bit of searching though and I'm not sure that it will be any cheaper.
One thing to remember when ordering pieces from the catalog outfits is that freight can run up the tab in a hurry to where it is way above the price that a good local muffler shop will charge. |
#15 | |
#16 | |
Middle-aged Curmudgeon
The Walker stuff fits perfect all the way back to the muffler, and the tail pipe is also correct, but the muffler is WRONG. It's too long and the inlet is the wrong size. I'm stalled on my exhaust at the moment until I get a chance to peruse the Walker catalog for a muffler that fits, but I've got lots of other stuff to work on to keep me busy. I'm with mrein3-- I prefer a clamped together system too. I've hung and fixed lots of exhaust, and would much rather be able to take it apart and fix it myself rather than deal with a system that's welded together from the doughnuts to the tailpipe outlet. Pros and cons both ways, I suppose.
Bret Check out the site's Truck Tech FAQ. Be a site supporter. My more-or-less pathetic build thread. Board members I've met: ------------------------------ Longhorn Man Dieselwrencher jholley big mike71 |
#17 | |
![]() If I ever have to do another exhaust I'll take it to a shop, because it's worth the extra money to get it done if modifications are necessary. Plus, I got an O2 bung welded in for no extra cost. If you're on a strict budget, the bolt on may be the way to go.
Curry in a Hurry: SB rebuild for my 71 C20 Last edited by pmpski_1; 03-06-2009 at 10:47 AM. |
#18 |
Go straight to heartthrob- I did and got free shipping - total was 184.00 w/o mufflers. It arrived today and I will let you know Sunday how it fits.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
#19 |
Aluminum slot wheels rule...
After gumping an exhaust together in my shop, and using a pipe bender and putting my truck on a car lift to re-do the exhaust, I'll NEVER gump another exhaust up again. Pay the extra money and have a shop do it, you wont regret it.
#20 |
I have the LMC kit on my 70 4x4 fit is Good and it was easy to install.
Ron
Member #111 68 C-10 ![]() 70 ![]() 76 Jeep CJ-5 Help Support the Board: http://67-72chevytrucks.com/vboard/payments.php He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors. Thomas Jefferson |
#21 |
I started on my heartthrob pipes last night and all fits very well and has instructions etc. I used walker components on my bb truck when I worked at the parts store and they fit without problems as well. Problem is a) don't work in parts store anymore b) no one sells walker in this town
#22 |
Barrito Loco Diablo
I think a good part of my truck was rebuilt using LMC. The previous owner had alot of their parts put on at some point. The dual exhaust is straight pipes with turbo mufflers and tips. The whole thing is clamped on. stock manifolds. It sounds decent, the clamps are obnoxious though. It looks cheap.
I'm gonna ditch the whole thing and just buy some good headers and have the shop weld up a custom, solid exhaust. Money well spent in my opinion. |
