Need to move bed for sending unit install?
Just a quick question - Will we need to move the bed back to install a new fuel tank sending unit? I assume it will be hard to attach the fuel lines with the bed on the truck, but just wanted to make sure before tomorrow.
What's your preferred method of replacing the tank/sending unit?
Blue - 77 Chevy Scottsdale |
Re: Need to move bed for sending unit install?
I got the bed off my truck right now , and you still can't get to the fuel pump so I would suggest just dropping the tank. You should be able to get to it without removing the bed.
GROUND ZERO IS R LIMIT ![]() |
I tried just "dropping the tanks", but had to lift the bed in order to unhook and reinstall the fuel lines.
Greg
1995 GMC 4x4 1/2 ton 1999 Jeep Wrangler w/ 33's 68 camaro 350/350 1987 Chevy 3/4 ton 4x4 Suzuki DRZ 400s Dual Sport 1971 chevy long bed 2x4 194? Dodge 2.5 ton 1980 Chevy Cheyenne 4x4 1/2 ton I6/sm455 1989 Chevy V30 crewcab dually 454/TH400 |
We did it yesterday and also had to lift the bed. There just no way we were getting the job done without moving the bed.
Arrived on a Pale Horse
kcackler, I wish I'd have found your thread a few days ago. I just replaced my gas tank, and this is what it took to get to the lines to disconnect/reconnect them. If you ever use this method, make sure you stack plenty of 2x4's between the box and frame, don't want anyone's head getting chopped off.
Jason 87 V30 350TBI/400 White w/Boss V-plow 89 R3500 CC SRW |
That's actually exactly what we did, Jason. It was the only way I could figure how to reattach everything.
OL BLUU
![]() Join Date: Mar 2004
I removed my tank without raising the bed... its tight but it is possible.
Thanks, Anthony
More Drop and pics... whatch'a think?: http://67-72chevytrucks.com/vboard/s...d.php?t=249927 My recent 2wd Blazer progress thread: http://67-72chevytrucks.com/vboard/s...d.php?t=393427 http://67-72chevytrucks.com/vboard/s...d.php?t=394870 |
I've pulled tanks by unbolting the brackets from the frame and cutting the hoses, but this was purely for removal.
To reinstall, my plan is to install a length of new hose onto the tank, snake it over the frame, then install the tank.
1977 GMC Sierra Grande |
#9 | |
ditto on what pyrotechnic suggested. worked for me.
![]() 76 Silverado, 2wd, long box, 350/th350, 3.42 posi, edelbrock performer 64cc heads, edelbrock 1405, 2101 intake, Hedman Headers, Comp Cam XE262 http://beerbreadbike.wordpress.com/ |
