Active Member
![]() Join Date: Nov 2008
Lowering Question
Hey All...I need some measurements. Could some of you kind people give me your measurement at the rear-end from the top of the rear-end (Axle) housing to the bottom of the frame (where the housing would hit if lowered to much). Also include your lowering spring (drop) height,, 2", 3", 4" etc...
*****Only one's from non-notched frames please***** Thanks in advance ! ! ![]()
*K10 SWB. Orange/White *69 Ford F100 21K Actual Miles, 2nd owner in family since new *67 Chevy II RestoMod, Wilwood all around, Heights Pro G front sub,, Shockwave Air Ride, 383cu in etc.. |
WTB this ad
Re: Lowering Question
Early Classic will tell you that their 6" drop coils leave 3" between the frame and the axle...Mine ended up a bit less.
I just meausured mine this week as I am in the process of relowering my truck and the measurement from the top on the axle to the frame is exactly 3 1/2 inches the guys at Early Classics said that it could be a 4 or 5 inch spring but I dont know as my truck already had this stance when I got it. The pict below maybe can give you an idea of how mine sits with a 20 inch wheel and a 295/40/20
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
the boat guy
im 1/2" fom the bumpstops on a 5" spring from ccp
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
if you let the air out of the bags ( and you're gonna want bags
Active Member
Thanks for the reply's. Below is a pic of mine (not to good) and I have the rear springs out and it's sitting on the leaf overloads and I like where it's at, thats why I was wanting info from all of you on where your at with distance/springs due to I have none in place. Before I pulled the bed/cab etc. I wanted to know in advance what I need. Keep the measurements coming, atleast a few more, even some stock height's..
