![]() Join Date: Mar 2006
weird tach dash
Here's pics of that weird tach dash I just got. I think it might have been a C40 or C50 truck as I can't figure out what the gauge on the right is?
Roadtrip!
![]() Join Date: Feb 2003
Re: weird tach dash
Never seen anything like that. I am not sure what the reasoning is. I am going to guess it was made by someone and not factory. Just a guess... Pic of the back?
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
Re: weird tach dash
The back looks orginal. The only thing that looks modified is the hole on the righr side of the bezel.
#4 | |
![]() Join Date: Feb 2002
Re: weird tach dash
Also it's from a '70 or later rig. '67 & '68 trucks had the Wiper-Washer switch on the left above the Lights switch. TDave-- I agree, the letters looks like LetraSet, a dry transfer decal you could use a stylus to rub letters onto surfaces. Very big before computers. I wonder how he rigged the Vac gauge? The needle is GM, perhaps off the stock Fuel gauge and Speedo. Could be a surplus A/N aircraft Mixture gauge ['40s - '60s vintage] -- bombers and transports had larger instruments. Vacuum gauges are aneroid instruments, not electrical.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 03-09-2009 at 06:20 AM. |
its all about the +6 inches
Re: weird tach dash
very interesting... it was in a 10 - 30 series, the 40 and bigger trucks bezal wasn't like that... close, but not quite the same.
Looking at the way the numbers are on that vacume (???) guage, it kinda looks 'custom'... but the fuel guage looks so ... factory. |
#6 | |
blood type; Retumbo
Re: weird tach dash
a 5000 RPM tach and a vacuum gauge favoring the lower end (10 to 15") makes me think a V6. but I would think a V6 would have a speedo that only goes to 50 MPH. ![]() how did you acquire it? do you know the application by chance? or for that matter which region of the country it came from? my truck has a rear view mirror that I have never seen anywhere else. it IS original, but the PO/OO bought it new from an implement dealer. edit; I see the lights on the left and wipers on the right. that means 69 and newer, right? Last edited by 68C15; 03-07-2009 at 07:03 AM. |
#7 | |
Re: weird tach dash
the tach is the same one that came with normal gas engines.... 5 grand is the highest tach you could get in a 10 - 30 series.
Attached is an inst panel in a C/40 and up truck... look where the column comes up, if you don't see it right away, then scroll up to the one in question. And after asking my dad (a Cessna owner) I have to agree with the following... Quote:
BlahBlahBlah
Re: weird tach dash
Those only came in Corvette optioned trucks. Special hand painted vacuum gauge numbers too.
... Last edited by CG; 03-07-2009 at 01:42 AM. |
#9 | |
454 MAKES IT ROAR
Re: weird tach dash
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger |
Re: weird tach dash
Someone painted on those numbers trying to emulate the font of the original. Maybe they were running turbo and wanted the gauges to look as stock as possible.
Re: weird tach dash
Sure looks like it's calibrated at 0 -30 "Hg, with a green/yellow/red band like a mid-70s Cessna 150 Manifold Vacuum [Mixture] gauge.
May be rigged for some heavy-duty hard hauling ore trucks that have to climb out of a pit with a big load. The hip pocket fuel gauge is interesting, too.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 03-07-2009 at 07:13 AM. |
Re: weird tach dash
We can question the vacuum gauge,but that fuel gauge makes it factory for me.Even if someone with alot of talent painted up the gauge,what gauge is it and how would it work properly?The vacuum gauges we`re used to aren`t used for gauging fuel consumption,color-coded ones are and they need to need larger to me more visible.The bezel could be swapped or maybe in a special lighter truck.How about a +11,000# C/30?
Re: weird tach dash
Could it have something to do with a PTO option?
Re: weird tach dash
Well I'm not really sure what it came from but I will most likely rebuild it and put a big fuel gauge back where the (not sure what its for gauge is). It is very interesting though!
#15 |
Roadtrip!
Re: weird tach dash
Can we see a better pic of the fuel gauge? And a pic from the back? If you look close at the "vac" gauge, you can see the idiot lights at the bottom. Pretty sure that is a fuel gauge that was modified. Backside pics could help determine. Pull the sockets out and hold it up to the light and see what they read. I would think the little fuel gauge would be electric. How does that hook up? If it is just for looks i would say it is an oil gauge that had the L and H touched up. I think someone had alot of time into this for some reason. I think it is pretty neat...
#16 |
Re: weird tach dash
Looking again I can see the letters show it`s home made.The p.o. of my `72 GMC mounted a vacuum tuning gauge that`s still there.It`s cool,you can monitor your fuel/air mix for optimum mileage.
#17 |
Re: weird tach dash
Looks like they made the fuel guage out of a oil pressure guage face. The 'E' lines up so they just had to black out the other letters and turn the 'P' into an 'F' and so on.
1972 GMC LWB, 250, 4sp 2010 GMC Sierra 6.6 CCSB |
#18 |
![]() Join Date: Aug 2004
Re: weird tach dash
Someone probably used a re-calibrated water temp gauge for the fuel gauge. If you change the resistor on the back of the gauge, it will read with different sensors. I re-calibrated my temp gauge so it wouldn't be in the red at 200.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3 lift & 6-speed 02 E320 the insurance total free car 13 Tahoe LTZ |
#19 |
Restoring a 68 SWB
Re: weird tach dash
Also, look real close at the letters in "FUEL". There's something a little weird there. The first two letters are lower than the last two. The letters in the other guages don't have this oddity. Not "buying it".
My Build Thread: Lucy - My 1968 SWB - Shop Truck Style North Nashville Concrete Contractor Last edited by tdave00; 03-08-2009 at 02:31 AM. |
#20 |
Recovering 67-72 Addict
![]() Join Date: Oct 2000
Re: weird tach dash
Do the "dummy" lights have the same labels as a standard fuel guage?
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt. "Friends call me cruzer cuz I like fast cars and fast women" |
#21 |
Re: weird tach dash
I believe it`s home made,a decent job,really a cool idea,and would like one like it.why does the fuel gueage need to be as big as the speedometer,anyway?
#22 |
![]() Join Date: Jun 2007
Re: weird tach dash
I like the small fuel gauge. Shoulda been made that way and a bigger tach in the place of the big gas gauge.
#23 |
Re: weird tach dash
Yeah, but where would you put your Vacuum gauge? [I just remembered they called it a "Suction" gauge in aviation -- "Mixture" was the rod control next to the throttle that went from Lean to Rich and was connected to the carb. It's been a while.]
