Old 03-08-2009, 01:56 PM   #1
72step
72step's Avatar
Heater Hose-Dual Feed Carb Issue
How do you all with dual feed carbs and a heater hose that taps into the intake handle the plumbing? I installed a dual feed carb last year and ended up bypassing the heater for now, but I want to do it right. It seems if I could find a 5/8" barbed elbow that would go into the intake instead of the straight barbed 5/8" fitting; would be the easy fix to prevent the fuel and heater hose lines to cross paths, but I can't seem to find one. Any ideas? Thanks.
Pics would be very much appreciated!
72step is offline   Reply With Quote
Old 03-08-2009, 02:07 PM   #2
cdowns
cdowns's Avatar
Re: Heater Hose-Dual Feed Carb Issue
any auto parts store should b able to get a 45 or 90 fitting even a good hardware store should have it too
Old 03-13-2009, 05:31 PM   #3
2 Many Toys
Not sure if you want chrome or not, but there are Chromed Brass 90's on eBay. I have bought them before.
2 Many Toys is offline   Reply With Quote
Old 03-14-2009, 02:33 AM   #4
71chevytruckguy
71chevytruckguy's Avatar
put a inch or 1/2 inch carb space on it and problem sloved. what i had to do. chris.
its a work in progess.
71 c-10 lwb, in the middle of frame off restoration.
69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump.
7.807 @ 88.37mph 1.60 60FT
80 g-20 van, tow rig, cammed 305, th350, 10 bolt
88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's
71chevytruckguy is offline   Reply With Quote
