Old 03-09-2009, 10:22 AM   #1
68c10owner
68c10owner's Avatar
heater question
My heater blows really good but it doesn`t feel to hot. It`s more warm than anything. What can I do to make it blow hotter air?
Anthony
68c10owner is offline   Reply With Quote
Old 03-09-2009, 05:36 PM   #2
tvblazer78
Low & Fast!
tvblazer78's Avatar
Re: heater question
What thermostat is in it? If it is a 160 that could be part of it. One more thing I would do is flush your coolant.
tvblazer78 is offline   Reply With Quote
Old 03-09-2009, 06:05 PM   #3
68c10owner
68c10owner's Avatar
Re: heater question
I don`t know what thermostat it has but it runs around 190-200* according to the factory gauge. The coolant was just done before i got it but it does have air in the system I think. I hear water flowing through it but the radiator and res. is full.
Anthony
Old 03-09-2009, 10:46 PM   #4
schoolfire
schoolfire's Avatar
Re: heater question
Heater core could be blocked? Its easy enough to check... I would disconnect it and try running water through it and see if its slow. If that isnt slowed I would check the lines running to/from radiator/engine and heater core.
Could also be the heater control valve if it had one.
Lots of rusty but trusty...
1978 Jimmy, 1979 K1500, 1980 C10, 1955 Belair, 1971 Camaro
schoolfire is offline   Reply With Quote
Old 03-10-2009, 12:50 AM   #5
68c10owner
68c10owner's Avatar
Re: heater question
I can hear water flowing through the core so I don`t think it`s blocked. I`ll look for a heater control valve. It does have a/c if that matters.
Anthony
Old 03-10-2009, 01:14 AM   #6
schoolfire
schoolfire's Avatar
Re: heater question
The control valve just limits the flow of water to the core. If there isnt a valve on the supply lines to open up I would still check for flow through the core... it just sounds like the core isnt ever getting hot enough to provide you with sweet warmth.
Old 03-10-2009, 01:24 AM   #7
68c10owner
68c10owner's Avatar
Re: heater question
So how do I check it then? I have a/c so I can`t just unhook the hose.
Anthony
Old 03-10-2009, 01:53 AM   #8
schoolfire
schoolfire's Avatar
Re: heater question
Since I dont know hows yours is setup I took a picture of my trucks heater setup in hopes it might help. I dont know how much it is different but its pretty basic. I would disconnect your core supply lines at the engine and radiator to avoid hurting the core...
Hope that helps
Forgot to mention that the heater core never ties into the A/C... it just gets water from the engine and radiator.
Old 03-10-2009, 08:41 AM   #9
tvblazer78
Low & Fast!
tvblazer78's Avatar
Re: heater question
schoolfire, Thanks for taking the time to help out. good stuff.
Old 03-10-2009, 11:54 AM   #10
68c10owner
68c10owner's Avatar
Re: heater question
Yes thanks alot. Mine is a 90 but should be similar so i`ll check it out this afternoon when I get home. I forgot about the heat and a/c being seperate. for some reason I was thinking they were tied together but I remember my old 75 gmc was a a/c truck with the a/c stuff missing and the heater worked great. I`ll check the core for blockage. How hard are they to change? I`ve never done one that have the a/c box too. Are they any different? Thanks again.
Anthony
Old 03-10-2009, 12:06 PM   #11
schoolfire
schoolfire's Avatar
Re: heater question
They arent too terrible to replace... I had never done one before and I recently changed the one in the truck in the picture and it took me ~3 hours. I dont remember if the A/C stuff got in the way but I dont think its a big deal.
Old 03-21-2009, 10:32 PM   #12
68c10owner
68c10owner's Avatar
Re: heater question
Well a little update. i let my wife drive it to work the other day and she said the heater worked just fine. I did find out it has a 180 thermostat but I`m thinkin I`m just not driving it far enough to get the temp up to where it blows hot. I do need to do something about the "flowing" sound still. I think I do need to adjust the cables because the defrost doesn`t blow on the windshield at all.
Anthony
Old 03-22-2009, 10:32 AM   #13
tvblazer78
Low & Fast!
tvblazer78's Avatar
Re: heater question
Thanks for the update...
