Old 03-09-2009, 11:16 PM   #1
SinDog
SinDog's Avatar
Ashtray Help
This may sound like a stupid question, but is there a way to remove the ashtray door and replace it with another one? The one in my '84 will not stay up. I don't smoke, but I don't want to look at it open nor close it permanently. I notice, what looks like, a tension spring. Would replacing that that solve my problem? Thanks in advance.
SinDog is offline   Reply With Quote
Old 03-09-2009, 11:20 PM   #2
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: Ashtray Help
yes you can, it's held down by fours screws 2 inside and 2 at the bottom of the dash,you will be able to bring out from the bottom of the dash or through to opening, also if you remove the glove box it can come out that way
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 03-09-2009, 11:24 PM   #3
dammitmitchell
the pollock
dammitmitchell's Avatar
Re: Ashtray Help
check teh spring and see if it's broken.. there is a "way" but the way i have done it has been pretty shade tree
it takes love and time =-)
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 03-09-2009, 11:31 PM   #4
SinDog
SinDog's Avatar
Re: Ashtray Help
Thanks for the fast responses, and the the news is good to hear. I did not want to experiment on mine, in case I went past the point of no repair. I'll check on it in the next couple of days. I don't think there is a problem with the spring, but I am not positive on that. Do I need to be careful with the spring when removing it? Is it a pain to put back in? I think that if I need to replace the door, I found one in an '85 that I can get.
Old 03-09-2009, 11:53 PM   #5
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Re: Ashtray Help
If it won't close, your spring is broken. I have put a new one in without pulling it down, but it takes some patience.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 03-10-2009, 06:29 AM   #6
staggerd86c-10
Squarebody Aficionado
staggerd86c-10's Avatar
Re: Ashtray Help
i have the same problem but my spring isnt broken its just out of place how can you do it without taking it apart it was kicking my ass last time i played with it i got fustrated and told myself it was better to leave it like that cause if not i was going to put my foot thru the dash.
staggerd86c-10 is offline   Reply With Quote
Old 03-10-2009, 05:02 PM   #7
SinDog
SinDog's Avatar
Re: Ashtray Help
OK, I looked at the spring and the one end happened to be out of place where it connects to the side of the dash. I pulled the ashtray out and reached back and pushed it back in place so now it works. The sad thing is that I have owned that truck over ten years, and it took me less than five minutes to fix the problem. lol I should have found this site sooner. lol
