Old 03-10-2009, 01:31 AM   #1
Andy4639
Old member
Andy4639's Avatar
Wheel adapters
I was wondering what does everyone think about wheel adapters. I found a really good buy on a set of Corvette wheels and tires.
C5 corvette wheels 17x9.5 18x10.5 They will be put on my 71 which I drive everyday.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 03-10-2009, 01:51 AM   #2
OARNGESI
OARNGESI's Avatar
Re: Wheel adapters
I had a set 1.5 inch to clear the breaks but you may really want to check your backkspace it looks really deep
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 03-10-2009, 02:29 AM   #3
Andy4639
Old member
Andy4639's Avatar
Re: Wheel adapters
He said I could come try them on before buying them. But I would need the spacers before I could tell if they would fit.
Old 03-10-2009, 08:50 PM   #4
onlyifihadachevy
Re: Wheel adapters
the adapters work just as good as normal lug spacing just the wheels are issue if u really want them its worth it
72 gmc 2500 2wd drive convert
My 72 thread
http://67-72chevytrucks.com/vboard/s...d.php?t=346712
THe other truck, wheeler 69 1/2 4x4, yellow and rusty.
http://67-72chevytrucks.com/vboard/s...d.php?t=350300
onlyifihadachevy is offline   Reply With Quote
Old 03-10-2009, 09:37 PM   #5
Andy4639
Old member
Andy4639's Avatar
Re: Wheel adapters
What kind of wheel issues are you talking about.
Old 03-13-2009, 12:30 AM   #6
onlyifihadachevy
Re: Wheel adapters
the different bolt patterns because it sounds like u have a 6 lug and i count 5 lugs on the corvette
My 72 thread
Old 03-13-2009, 04:24 AM   #7
Andy4639
Old member
Andy4639's Avatar
Re: Wheel adapters
The wheels are 5 lug on a 2 wheel drive starting in 71. Chevy made 2 differant lug pattern's though for cars & trucks. This is why I'm asking. Do people think the adapters are safe for everyday use.
Old 03-13-2009, 07:12 AM   #8
67_C-30
I have a radical idea!
67_C-30's Avatar
Re: Wheel adapters
As with anything there will be detracters, but I have used billet wheel spacers/adaptors on race cars, 4X4 trucks, and even my ramp truck. I have a set on my 'red. Make sure you get billet ones (I wouldn't use those cheap cast ones) and forget about them. I use a little of the mild loctite on the studs (on the truck) and I've never had them them come loose or anything else. I'd had more weight on my ramp truck than you could ever put on your pickup!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 03-13-2009, 08:11 AM   #9
Andy4639
Old member
Andy4639's Avatar
Re: Wheel adapters
Yea the billet ones are what I was looking at. I can get a lot more choices of wheels with them also.
