Old 03-10-2009, 10:34 AM   #1
b00sted
b00sted's Avatar
How to remove leafs from leaf springs..
just like the title says... I want to go ahead and get the 8.8 in the truck and use the spring perch method for now and was wondering how to remove some of the leafs.. My truck has a good number of leafs on the springs and it sits way up there.. I am of course going to mount the rearend ontop of the leaf spring instead of under it..
But need a bit more to get it where I want it and do not want all those leafs hanging under the rear axle..
Alos how many should I take out .. i am never going to haul anything in the bed of this truck or towe anything with it.... As you can see in the pic it is up there...
1949 Chevy 408 CID stroker 6.0l with a few add ons, 4l80E, 4 Wheel Disk Brakes and a set of GT35 going on soon.
b00sted is offline   Reply With Quote
Old 03-10-2009, 01:04 PM   #2
mylow53
mylow53's Avatar
Re: How to remove leafs from leaf springs..
have you thought about bending them instead?
GT
Greg
1953 chevy 1/2 ton 5 window, chevy 350 330 horse 700r tranz, lowering spindels mustang 2 frount. ford 9", airbags on 4 corners . purchased in 1983 for $325 while in high school
http://67-72chevytrucks.com/vboard/s...=215079&page=5
mylow53 is offline   Reply With Quote
Old 03-10-2009, 01:11 PM   #3
OrrieG
OrrieG's Avatar
Usually they are bolted together with one center bolt at the perch location. They may have some U type clips or side plates bolted together holding them in alignment. Once unbolted they should fall off, depending on how much rust there holding them together. The main spring is attached to the shackles.
Old 03-10-2009, 01:14 PM   #4
b00sted
b00sted's Avatar
How many is safe to take out? Should I stick with a leaf and the main spring? I think it has 4 or 5 on there now...
Old 03-10-2009, 01:34 PM   #5
mylow53
mylow53's Avatar
i took out 3 in the front to get it down. all of the strength is in the primary spring as far as keeping the axel centered. the amount of springs depends on the weight of the truck and load. your call
GT
Greg
Old 03-10-2009, 01:59 PM   #6
b00sted
b00sted's Avatar
Thanks for the help guys.. I have to move the spring perch on the 8.8 but that is no big deal..
I will be yanking these out this weekend....
Old 03-10-2009, 06:19 PM   #7
blackdiesel
blackdiesel's Avatar
As far as leaf springs go, just take the pin out of the center and pull out as much as necessary. On my '38 i'm just running the single leaf in the rear. Just make sure to get a really stiff shock. Possibly even air shocks if desired
Now i've seen where you are wanting to "drag the boards" so why are you even wasting time with leaves? in order to achieve your goal you are looking at a set of air bags and a 4 link. dont forget the c notched frame!
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
http://67-72chevytrucks.com/vboard/s...light=speedway
blackdiesel is offline   Reply With Quote
Old 03-10-2009, 06:27 PM   #8
blackdiesel
Also, be sure to lower the front end where you desire it for ride height before you weld your spring perches on the rear end! or your pinion angle will be wrong
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
Old 03-10-2009, 07:02 PM   #9
b00sted
b00sted's Avatar
won't be dragging the boards on this one anytime soon.. It has a c10 fron IFS in it right now so I am going to pro street it...
Old 03-10-2009, 07:30 PM   #10
blackdiesel
a pro street or a street rod? for a true pro street your talking a narrowed rear end and tubs. a street rod would make for a real nice daily driver
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
Old 03-10-2009, 09:47 PM   #11
b00sted
b00sted's Avatar
planning on back halfing it...
