Old 03-11-2009, 11:57 AM   #1
bigchad64
'66 c-10 starting issues
I came home from driving my truck last week and was working on some instrument lights, and when I tried to start my truck again, didn't start. It will turn over and act like its catching (meaning if I continued to keep the key in the start position would cause starter to grind). I thought maybe I had let it get too low on fuel, so I put in some gas I had in the garage. No luck. Fearing I had put in some bad gas I drained the gas out, put in 4 gallons of fresh gas and took the carb off to clean. Put carb back on, put in some new plugs and same problem. If I pour gas into the carb it will allow me to crank until gas is gone, but then same thing...acts like its catching but nothing.
I'm afraid now that maybe when I was fidgeting with the control lights maybe I screwed something up electrically. The carb bowl is filling up with gas, so I don't think its a fuel problem at this point.
With this amazingly vague description, any ideas how I should chase this down?
Thanks Chad
bigchad64 is offline   Reply With Quote
Old 03-11-2009, 11:58 AM   #2
bigchad64
Re: '66 c-10 starting issues
And by the way...I miss driving it
Old 03-11-2009, 12:11 PM   #3
hewlett2002000
hewlett2002000's Avatar
points or hei? if your running hei run a 12v line from the battery and try to start it. that will tell you if your not getting proper fire to the dizzy.
John
Respect:
1. A feeling of appreciative, often deferential regard; esteem.
2. The state of being regarded with honor or esteem.
3. Willingness to show consideration or appreciation.
When you fail to show consideration to others values you are showing disrespect.
hewlett2002000 is offline   Reply With Quote
Old 03-11-2009, 12:30 PM   #4
bigchad64
John
Haven't looked, but I'm guessing points...
Old 03-11-2009, 01:05 PM   #5
jchav62
1962 C-10
jchav62's Avatar
Were you working under the dash fixing those instrument lights? Maybe one of the wires from the ignition switch got knocked loose or broken in the process.
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 03-11-2009, 01:58 PM   #6
joe231
joe231's Avatar
did you have the key on for an extended period of time?
if you are running points, the key on could have fried the points.
IMO points are troublesome and require almost constant attention
check the points and see if they are burnt.....then get a HEI
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 03-11-2009, 02:01 PM   #7
MacAttack
283 Drama Queen
MacAttack's Avatar
What Joe said........
Mac.
For about 12 years of my adult life I had a severe speech impediment.
My ex-wife never let me get a word in edgewise.
MacAttack is offline   Reply With Quote
Old 03-11-2009, 03:42 PM   #8
jchav62
1962 C-10
jchav62's Avatar
Mac.
Yeah, what Mac said about what Joe said... HEI
Joseph Chavez
Old 03-11-2009, 03:45 PM   #9
bigchad64
i just pulled and tested the coil. it is reading outside the specs on both the inner and outer coil. could this cause the problem?
Old 03-11-2009, 03:47 PM   #10
joe231
joe231's Avatar
how did you test it? Ohm-ed it? what is your spec and what were your actual readings?
did you check the points?
CHEVY ONLY
Old 03-11-2009, 03:50 PM   #11
bigchad64
points looked ok
ohm'd it...
outer coil should have tested 1.5-1.7, checked at 2.0
Inner should have tested 5600-7100 and checked 7600
Old 03-11-2009, 04:02 PM   #12
jgarverick
doesn't sound like its far enough out of spec to not start. getting any spark at all while cranking? i'm betting something got knocked off or broken while you were workin under the dash.
Jason Garverick
64 C10 SWB Stepside 350/muncie - 5.3 vortec (soon)Thread
69 AMC Javelin 360/auto - 417 stroker (soon)
68 Scout (Basketcase)
06 Ram HEMI SWB Reg Cab Daily Driver
US Army Vet
jgarverick is offline   Reply With Quote
Old 03-11-2009, 05:05 PM   #13
kizer
Its Deja Vu time again
kizer's Avatar
Yep. You could pull one of the spark plug wires and have somebody turn the key and see if you are getting a spark. If your not getting a spark I'd guess well your getting power to the starter, but not to the rest of the system.
Been there done that before. My old bug was famous for having wires fall off the terminal block.
Its not pretty but its mine to figure out.
The build / The Photos / Build Diary
kizer is offline   Reply With Quote
Old 03-11-2009, 07:02 PM   #14
joe231
joe231's Avatar
yeah
it isn't too far out of spec........but if you have another lying around, give it a try
CHEVY ONLY
Old 03-11-2009, 11:03 PM   #15
bigchad64
Ok...its been a few years since I restored anything, so I forgot one of the keys to chasing down a problem...start with the simple, most obvious things first.
When fiddling around with the wires under the dash, one of the wires from the ignition switch got unplugged. It fired right up once reconnected.
So...It only took about 3 hours worth of work to figure out something I should have found in 3 minutes...lesson learned.
Thanks for the input.
Old 03-12-2009, 08:08 AM   #16
joe231
joe231's Avatar
that same thing happened to me.......but it wouldn't even try to fire, just crank and crank
glad you figured it out
CHEVY ONLY
