Old 03-13-2009, 12:24 AM   #1
willett
Another Day, Another Dollar
willett's Avatar
what is a kickdown cable?
hey guys, bit of an idiot question....
where is it and what does it do?
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 03-13-2009, 12:30 AM   #2
87c10slammer
truck addict
Re: what is a kickdown cable?
it is a cable that is connected to your throttle and to the tranny... when you press the gas from half throttle to full tilt it makes the tranny kick down into a lower gear and allows you to pass someone easier or to pick up speed faster... some are vacum controled though and im pretty sure our trucks are.. mine no longer is but thats another story...
trucks
87c10slammer is offline   Reply With Quote
Old 03-13-2009, 12:33 AM   #3
willett
willett's Avatar
i was lookin on my truck's gas pedal, and when the pedal arm passes a certian point it pushes a sliding switch.
is this kickdown actuation or something else?
also i had hear that either the turbo 400 or the 700r doesn't have one. wich is it (if either)?
Old 03-13-2009, 01:32 AM   #4
88 Dippy
88 Dippy's Avatar
700-R4 needs to have one hooked up (bad things happen) someTH350 have a Kick down as well but it is not need as mutch as the 700-R4. i think TH400 where only vauum
please correct me if i am wrong
1974 chevy Cheyenne C10 "The Mutt":4x4 convertion, NP208, 700-R4, stock 350, edelbrock Torker intake, edelbrock 600 CFM carb, duels
2001 Pontiac Grand Prix GT: 3.8L supercharged, 9.2:1 comprestion, ZZP XP cam, home made intake, 2 1/2" exhuast, 10psi of boost
88 Dippy is offline   Reply With Quote
Old 03-13-2009, 01:32 AM   #5
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Your 78 model has a TH400 from the factory backing up your 454BB.
The tranny has an electric kick down that is activated by that switch you see above your GO-PEDAL. The TH350, TH200 & early model TH700R4 trannys were all cable actuated. My '90 V2500 Suburban has a TH400 but no switch mounted above the GO-PEDAL like yours. Instead it's controlled by the Throttle Position Sensor on the throttle body through the computer.
Both the TH350 & the TH400 have a vacuum modulator on them as well that help control the kickdown. The TH700R4 doesn't have one. Not very familiar with the TH200 though
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 03-13-2009, 07:26 AM   #6
mhicks
mhicks's Avatar
The 700R4 has what they call a TV (throttle valve) cable. It actually regulates the flow of tansmission fluid in the tranny.
mhicks is offline   Reply With Quote
Old 03-16-2009, 03:51 AM   #7
willett
willett's Avatar
thanks for the info guys!
