Old 03-15-2009, 04:42 PM   #1
jbobzien
Help getting my bumper off!
Howdy I have a 1978 Chevy C-10. The problem I'm running into is:
If you have seen these before I'm sure you know that the opposite side of that great lil bolt head is a rusted thread with a rusted nut on it. I got it loosened, but now that the whole bolt has wiggle room I can't stop it from going around with that smooth head on the outside. How can I get the rusted nut off the rusted threads? It won't come any further. I have already soaked the thing in WD-40 and tried working it forward and back with no luck. Any ideas on how I could secure that smooth head without destroying it??
Any help would be appreciated!
Thanks,
--John
jbobzien is offline   Reply With Quote
Old 03-15-2009, 04:46 PM   #2
dooce
Re: Help getting my bumper off!
Why are you worried about destroying the bolt? It needs replaced anyways right?
1976 Chevy 1/2T 2wd SWB
327/Saginaw 4spd 3.73:1
LQ4 6.0/T56 Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=772071
LFSalleeII@gmail.com
dooce is offline   Reply With Quote
Old 03-15-2009, 04:49 PM   #3
72freak
Rottenwood Garage Member
72freak's Avatar
Your going to have to cut, torch or grind!
Great design!!!!
2004 Chevrolet Suburban C1500
2001 Chevrolet 2500HD Crew 6.0
1999 Harley Davidson Electra Glide
1972 Chevrolet C-20 Custom Camper "Dump Truck"
1972 Chevrolet C-20 Suburban "Big Green"
1969 Chevrolet C-50 Wedge Hauler "Leonidis"
1966 C-10 2x4 short fleet 327 4 speed "Race Truck"
1952 Plymouth Cranbrook "Rican" (my grandfathers)
1931 Ford Model A Coupe "Black Beauty"
1930 Ford Model A truck "Club Cab" 4x4
Rottenwood Garage and Speed Shop.....where everything must be racy!
It's not just a hobby..It's a LIFESTYLE!!!
Thanks for nothing Barrett-Jackson
You cant fix stupid or teach accountability!
Time wasters, looky Lous and tire kickers are everywhere!
72freak is offline   Reply With Quote
Old 03-15-2009, 05:33 PM   #4
heavychevy79
Cheyenne Super
heavychevy79's Avatar
I would weld it to the bumper if I was just going to discard it anyway.
heavychevy79 is offline   Reply With Quote
Old 03-15-2009, 11:31 PM   #5
72 CustomCamper
huh ???
72 CustomCamper's Avatar
If you have anymore like that, instead of loosening them,try tightening them until they wring off. I've had to do that a few times...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 03-16-2009, 07:54 AM   #6
James McClure
One shot, one kill.
Hay Chuck, been a while since you posted. Anyways, that's a hell of an idea.33 years as a mechanic and I struggled with bumper bolts all the time and never even thought of snapping them off!! It's quick & easy and doesn't damage anything except the bolt. Good show. I'll keep this in the back of my mind. You should post this in the FAQ area. Lots of folks will benifit. jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shotJim or Paladin whichever you choose.
James McClure is offline   Reply With Quote
Old 03-16-2009, 02:33 PM   #7
72 CustomCamper
huh ???
I've been busy prepping the blazer for a heart transplant...
Chuck
Old 03-16-2009, 03:01 PM   #8
babyJay
Arrived on a Pale Horse
babyJay's Avatar
Use a pnuematic cutoff tool ($8 at harbor freight), make an X in the bolt head. Then use a pnuematic air chisel ($12 set same place), place on side of head, it'll pop right off of there. The new bolts are not that expensive to buy, and if the square carriage is rounded you need new ones anyway.
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
Old 03-16-2009, 03:51 PM   #9
Driveway Dreams
I have car A.D.D.
Driveway Dreams's Avatar
The idea to snap the bolt off is probably your best bet to not damage anything but the bolt. I use PB Blaster instead of WD-40. It works a whole lot better to really get in and get things loose. WD-40 is more of a lubricant.
Driveway Dreams is offline   Reply With Quote
Old 03-16-2009, 10:13 PM   #10
85Bowtie
85Bowtie's Avatar
You should be able to lock a pair of thin long nose visegrips onto the bolt if you have some. The just hold it with one hand and wrench it with the other, or, just wrench it around until the visgrips get "locked" against something like the bumper, then keep wrenching it off.
Use stainless when you put the new bumper back on.
85Bowtie is offline   Reply With Quote
Old 03-17-2009, 07:11 AM   #11
jbobzien
Thanks for all the great options guys! I'm going to put it off unfortunately when I went to start my truck up is started blowing very thick white smoke non-stop out of the tail pipe and muffler itself. It was making enough smoke to hide an army in about 10 minutes DOH! But when I do get back to the bumper I'm going to try a couple try a combination of what you guys suggested, as well as upgrading to PB Blaster!
Thanks a ton guys!
John
Old 03-17-2009, 09:48 AM   #12
mrbigshot
i suggest a head gasket or magnafluxing the heads before you worry about the bumper. .
personally i use the gas axe to cut them off but a $25 angle grinder from walmart works to.
mrbigshot is offline   Reply With Quote
