03-16-2009, 10:27 PM | #1 |
what are these called?
No prizes offered for the correct answer!
03-16-2009, 10:29 PM | #2 |
67 is sold
Re: what are these called?
Blinker fluid tank retainers
03-16-2009, 10:37 PM | #3 |
The Older Generation
Those are check straps to control engine roll. The humped bracket bolts to the frame rail and the cable fastens to it and bolts to the engine. LockDoc
03-16-2009, 10:39 PM | #4 |
its all about the +6 inches
yep, that was installed per a recall for broken motor mounts
03-16-2009, 10:59 PM | #5 |
thanks
03-16-2009, 11:02 PM | #6 |
what years and engine options, Ive had three a 68 69 & 70 never seen them before but it makes sense
03-16-2009, 11:06 PM | #7 |
Future TOTM Winner
I just pulled a set off of my 69 parts truck...350/th400 1/2ton lwb. I think alot of people probably pulled them off years ago when the motor was rebuilt. Plus if you use the new interlocking style motor mounts, you don't need them anyway.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
03-16-2009, 11:08 PM | #8 |
Hollister Road Co.
late 60's early 70's. That was a short lived recall until they redesigned the motor mount to the safety mount and then that was the replacement part. If you had a linkage type gas pedal you got that strap setup. Cable type pedals did'nt have the WOT problem.
