03-17-2009, 01:42 AM | #1 |
6.0 powered square
Interior help
today I finally got my door panels from the upholster, also the seats and kick panels are getting covered, but I'm having a hard time figuring out what I should paint, either blue or white that match the door panels or leave it alone
the upholster guy is a furniture upholster, and he didn't want to cover this the headliner trim dash dash bezel steering wheel seat belt re tractor cover sun visor's diamond plate keep it or change it and also where should I put the radio, headlight switch, heater switch it the switch that say's summit on it, and wiper switch it look's like the heater switch and also a speaker box can't decide on it this is what I have
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 Last edited by flamingbig10; 03-17-2009 at 01:46 AM. |
03-17-2009, 06:36 PM | #2 |
6.0 powered square
Re: Interior help
any one
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
03-17-2009, 06:55 PM | #3 |
Re: Interior help
man, tough choices... i'd replace the diamond plating for sure. thinking stock bezel smoothed and painted white and paint the gauge trim rings blue. do away w/ the summit control, (maybe paint blue) and try to get a double din radio,nav,dvd to fit in the old holes. just a thought...
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list |
03-17-2009, 08:12 PM | #4 |
Re: Interior help
get rid of the diamond plate. Get some clean stock parts on the dash and it will look great. I like the door panels.
2010 Tahoe 1984 C10 2005 Harley FLH 1941 Willys Pickup (will never get it done) not for sale Last edited by 1984 swb chevy; 03-17-2009 at 08:14 PM. |
03-17-2009, 08:24 PM | #5 |
Re: Interior help
weeeell
since you asked I think the diamond plate needs to go too the polished high class look of the door panels doesn't fit with the high tech industrial look of the plate in my opinion too much of a mix of styles but your truck is unique built to be what you want take some time and look at options it will come to you great truck -doing it your way good luck MArk
the avatar was my 62 I owned for 27 years 84 chevy short short bed black 84 gmc long bed copper/ buckskin 88 chevy k5 blazer white Life's short make the most of it Mark aka impalmark |
03-17-2009, 08:45 PM | #6 |
Re: Interior help
I would get rid of the diamond plate and go with stock interior parts as well.
I really like the door panels |
03-17-2009, 10:38 PM | #7 |
6.0 powered square
Re: Interior help
thanks guys for the input and compliments , I'm going to fiber glass the dash bezel and paint it white, and I found some plastic paint that match's the white material for the headliner trim, and the factory kick panel's are getting covered in white and I'm thinking about hiding the heater switch, what about wood in place of the diamond plate since my dad does wood work well, and recessing the gauges
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 Last edited by flamingbig10; 03-17-2009 at 10:40 PM. |
03-17-2009, 10:58 PM | #8 |
Re: Interior help
yea the heater switch does kinda stick out
I like the idea of a wood dash with the guages recessed -sweet ... and keying it to the color of the wood on the seat/ console would look sharp mark
the avatar was my 62 I owned for 27 years 84 chevy short short bed black 84 gmc long bed copper/ buckskin 88 chevy k5 blazer white Life's short make the most of it Mark aka impalmark Last edited by impalamark; 03-17-2009 at 10:59 PM. |
03-17-2009, 11:25 PM | #9 |
6.0 powered square
Re: Interior help
when I was mounting the switch I couldn't make my mind up where I wanted it so that's where it went, so it's going at the bottom of dash by the wiper switch it's the black knob,
03-18-2009, 11:38 PM | #10 |
6.0 powered square
Re: Interior help
I went ahead and painted the headliner trim white and moved the heater switch
before The trim started off blue then I went with a gloss white then I changed it to a shell white after
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 Last edited by flamingbig10; 03-18-2009 at 11:56 PM. |
03-19-2009, 06:01 AM | #11 |
Re: Interior help
Those look great and i agree to getting red of the diamond plate for stock pieces
70 SWB STEPSIDE 70 BLAZER 09 challenger |
03-19-2009, 11:21 AM | #12 |
Re: Interior help
Yeah get rid of the diamond plate. The billet one from lmc would look sweet and do the brushed aluminum pieces for the other diamond plate areas.
03-19-2009, 01:47 PM | #13 |
6.0 powered square
Re: Interior help
thanks OARNGESI, what stock pieces do ya"ll mean
03-19-2009, 08:48 PM | #14 |
Re: Interior help
stock bezel and piece that runs along the dash is what i was refering to.
03-20-2009, 12:09 AM | #15 |
Re: Interior help
kick a$$ door panel's flamingbig10. i really like em. how dose it sound with the JBL's .
03-20-2009, 01:03 AM | #16 | |
6.0 powered square
Re: Interior help
thanks, the jbl's have a little thump maybe a little more when I build a bigger box , along with Sony 4-Channel 600-Watt Xplod Amplifier, XMZR604R, and a Sony 5x7 in the dash zip tied, and one component box speaker that's older than my truck
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 Last edited by flamingbig10; 03-20-2009 at 01:12 AM. |
03-21-2009, 04:44 AM | #17 |
6.0 powered square
Re: Interior help
I thought about it some more, fiber glass the bezel, move the stereo to the factory location and wood trim for the dash
03-21-2009, 11:26 PM | #18 |
Re: Interior help
if you fiber glass the bezel i think that will look cool. i tought about it aswell but i'am going to go ahead and buy the billit aluminum bezel cover and i will be fiber glassing my dash.
03-22-2009, 04:35 AM | #19 |
>130dB Moderator
Re: Interior help
I'd be weary of the wood trim...
Nothing against your dad wood working ability, but the wood trim really doesn't fit the interior at all. Maybe if you stained it jet black and the proper grain pattern showed through, but I think it would be very hard to pull off and make it match the rest of the truck. For the speaker box, I'd ditch the shelf speakers (obviously) and just fit the subs and amps inside the box and use the kick panels as your mids and plant the tweeters in the dash corners. Maybe you could make a pod for them coming from the a-pillar. If you're in the mood for new equipment, I may have a box you can use... EDIT: I just thought of this, what if you could figure out a way to make the wood grain into flames...? how bad ass would that be...?
Living Life @ 130dB LED Tail Light Conversion; How-to Friend. Father. Brother. RIP El Jay ------------------------------------------------------------------------------------------------------------------------- CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum. Last edited by AceX; 03-22-2009 at 04:36 AM. |
04-21-2009, 01:47 AM | #20 | |
Re: Interior help
do you have any pics of the set up you are talking about? |
04-21-2009, 12:32 PM | #21 |
Re: Interior help
Heres a pick of what the box in my truck looks very similar to i cant get a picture of mine because the seat in my truck is a rear seat out of a suburban so it doesnt lift up but the box is for shallow 10 inch subs. Ok then man yea it looks good like that.
04-21-2009, 01:02 PM | #22 |
Re: Interior help
where did you get that box from?
03-22-2009, 01:18 PM | #23 |
6.0 powered square
Re: Interior help
the wood trim I'm having second thoughts on, for the box, I was going make one that went to cab corner to cab corner and I'll have make it flat in the middle for the center console/seat
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 Last edited by flamingbig10; 03-22-2009 at 01:24 PM. |
04-08-2009, 10:06 PM | #24 |
6.0 powered square
Re: Interior help
I believe the seats helped the interior now I need to work on the dash
04-09-2009, 12:43 AM | #25 |
Re: Interior help
hey what size are your subs? 10 or 12?
