03-19-2009, 05:47 PM | #1 |
Active Member
Need help.. Dana 44 leaking axle seals.
At first I thought it was the brake cylinder but found out it's leaking on the inside of the brake backing plate. I checked on the other side and there's no oil there.
I read something about replacing the seals but I can't figure out how to remove the pin on this sucker. Any ideas? |
03-19-2009, 06:14 PM | #2 |
Currently Blazerless
Re: Need help.. Dana 44 leaking axle seals.
The Dana 44 is not a C clip axle so you wont have to remove the cross shaft. There should be a 4 bolt retaining plate that also holds the backing plate on..remove that and the axle should slide out..you may have to try and lever it out or find a way to tap it out from the back side. You shouldnt have to use a puller unless its really stuck for some reason. You will have to have a press to remove the axle bearing since the seal is on the other side of it..but its a good time to replace those as well. Good Luck
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
03-19-2009, 06:25 PM | #3 |
Active Member
Thanks Blazerman. I spend 30 minutes trying to figure out how that pin comes out.
This truck was a ranch truck and only has 30K original miles on it. It's only been driven about once or twice a week. Do you think I should still replace the bearings? |
03-19-2009, 06:43 PM | #4 |
Thats your call..if they look good and no pitting or galling then you can probably get by with using them. But they do have to come off with a shop press in order to even get to that seal, if its something that still isnt driven much then I might just slap it back together....but if your starting to drive it more on the roads I would check into a set of Timpken bearings and just do this job once.
03-19-2009, 06:54 PM | #5 |
Active Member
I just started taking the bolts off the plate. I'll check the bearings when I remove the axles. Thanks.
03-19-2009, 07:42 PM | #6 |
Active Member
One more question...
Got the axle out and wiped off. Bearing turns smooth and firm with no noise or noticeable wear. However, it looks like this is a sealed bearing? Is this correct? There's also an oil seal at the end of the axle shaft. If it's a sealed bearing, I'll just have the Napa machine shop replace the bearing and l'll get the inner seal also. |
03-19-2009, 06:19 PM | #7 | |
03-19-2009, 11:20 PM | #8 |
I just did My Jeep CJ and they are setup the same way kinda. I don't think it is a sealed bearing but could be. The seals are cheap at Napa. Make sure ya seal the flange whith some silicone when you go back together. Hope this helps
Ron
Member #111 68 C-10 Daily Driver 70 4x4 Project 76 Jeep CJ-5 Help Support the Board: http://67-72chevytrucks.com/vboard/payments.php He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors. Thomas Jefferson |
