Old 03-19-2009, 11:04 PM   #1
72BLAZERDUDE
72BLAZERDUDE's Avatar
Front Rotors
How hard is to get the front rotors off of of my 78 BLAZER 4X4
72 2wd 307/AT/AC/TILT WHEEL
78 JIMMY HIGH SIERRA
72BLAZERDUDE is offline   Reply With Quote
Old 03-20-2009, 08:31 AM   #2
LONGHAIR
Re: Front Rotors
It is not "hard" but there is quite a bit of work involved. It is not like pulling a drum off from the outside.
First you have to remove the lock-out hub or the drive flange if it is an un-converted full-time truck. After that comes the caliper which is held on by two bolts (Allen head) Then comes the actual retaining nut/s. A special 4-pronged socket is very helpful in this. It is not absolutely required for disassembly, but it will help greatly when you put it back together.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 03-20-2009, 09:34 AM   #3
FormerMember
Re: Front Rotors
Basically, the rotor is mounted behind the hub, with wheel studs pressed through it, into the hub.
So you have to remove the caliper and entire hub, which is a great time to replace or re-pack the wheel bearings. Then use a brass faced hammer to knock out the wheel studs.
A time or two, I've bought rotor/hub combos that are already together with the wheel studs pressed in from Car quest for the price of a rotor alone. They also came with wheel bearings, if I recall correctly.
FormerMember is offline   Reply With Quote
Old 03-20-2009, 09:36 AM   #4
FormerMember
Re: Front Rotors
Pics are worth 1K words...
It's a picture of a Jeep 44, but same principle.
Your rotor sits behind part 40.
Like that
Old 03-20-2009, 12:38 PM   #5
72BLAZERDUDE
Re: Front Rotors
I actually need to replace all of the front wheel studs. I broke one off on pass side and two off driver side yesterday, so they are all getting replaced. I just wasn't sure how to get the front hubs apart. It is still full time so I will need to get the drive flange off and the retaining nut. Do I need any special tools for the drive flange. And I assume I can get the retaining nut wrench or socket at Napa. Probably do the ball joints while I have it apart. They are still the non greaseable originals.
Old 03-20-2009, 12:42 PM   #6
FormerMember
Re: Front Rotors
I have the sockets, but some people use a chisel and hammer to run the wheel bearing retaining nuts off.
For the wheel studs, you need to stop there.
For the ball joints, you need to take the spindle and axleshafts out... might as well do ujoints too
Make sure you rent a ball joint press, if you're doing them.
