Old 12-18-2002, 11:03 PM   #1
special70gmc
special70gmc's Avatar
hows this sound? 383?
speed-o-motive stroker kit, hyperuetecnic flat tops, world sr torquer 2.02 I 1.60E 64cc chambers 9.9:1 comp ratio with flat tops. edelbrock intake manifold, demon 750 carb, cam will be somewhere between 236 and 245 duration at 0.500. il have my th350 w/shift kit and a 4.10 gears in the rear, should be a sloid moter can you guys with the dd2000 run it through im also wondering what quarter mile it will run (just an estimate) im thinkin 13's maybe
1986 c-10 swb 5/7 drop 20'' coys
1958 belair 2door
special70gmc is offline   Reply With Quote
Old 12-18-2002, 11:17 PM   #2
my new 72
faster, faster, faster
my new 72's Avatar
your comp will be higher than 9.9 to 1 with 64 cc heads. mine is 10.2 with 72cc heads
I'm going to Law School, wanna debate? It's good practice.
my new 72 is offline   Reply With Quote
Old 12-18-2002, 11:25 PM   #3
MikeB
MikeB's Avatar
In DD2000, I used a 200cc Dart Iron Eagle airflow file and Comp Cams XE 284 (240/246). Numbers are 393 lb/ft @ 4500 rpm and 394 hp @6000. Be sure to spend some time and money on the block and make sure the crank spins easily by hand when torqued in place with new bearings. I'm not sure where there is any info or pictures on this, but you'll need to clearance the block in several places to clear the rods. Then you'll need to use rods designed for strokers and/or do some grinding on them to clear the cam lobes. If you can get the block decked to 9.005" and run a .038" gasket, you'll have a near-perfect .043 quench area.
Oh, yeah. Flat tops (with -4cc reliefs) with 64 cc heads in a 383 will give you somehere between 10.5 and 11:1, depending on deck height and gasket thickness. You'll probably need some 12cc dished pistons. Get the K-Bs with the D cup for a better quench.
Mike
1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 12-19-2002, 07:10 AM   #4
special70gmc
world also makes a 76cc head for the same price would you recomend going with them? i did the math (not good at math) and got 9.3:1 cr that sounds pritty good to me could be wrong on thatr though
1958 belair 2door
Old 12-19-2002, 08:07 AM   #5
mikep
Used to have a truck
mikep's Avatar
I run those heads and you cant go wrong with them although they do cc a little higher than 76. Mine came in at 78cc in almost every hole.
No truck :-(
mikep is offline   Reply With Quote
Old 12-19-2002, 12:02 PM   #6
MikeB
MikeB's Avatar
The latest conventional wisdom says you're better off with a small chamber head, and then use a piston with a D-shaped dish. Check out http://www.kb-silvolite.com for good tech articles on combustion chambers, quench area, pistons, clearances, etc.
I'm not sure about the WP heads, but many of the manufacturers like AFR and Dart are using heart-shaped chambers to promote swirl and reduce detonation. Even Edelbrock's latest heads use this new design.
Mike
Old 12-19-2002, 12:53 PM   #7
Blue68
Blue68's Avatar
Another excellent source for building your stroker would be the guys you are buying your kit from. They've been around a long time and probably have an engine that is similar to what you are looking at already to give you and idea of what to do. Truth be told, if you ask them these questions, they can probably tell you whether they've built your combination or not as well.
Their website http://www.speedomotive.com is also a good place to read up on quench, detonation and higher compression engines.
http://home.comcast.net/~r.landrum/w...tos.html-.html
'68 C-10 LWB, '98 Z-71 350 w/accessories (Serpentine), Edelbrock Performer, Edelbrock 1405 (600cfm) carb, GM HEI, CompCam Extreme 4x4 roller cam, Thorley Headers, Carter Electric Fuel Pump, Vintage Air, 700r4, 3.73, disc brakes and power steering upgrades.
Blue68 is offline   Reply With Quote
Old 12-19-2002, 07:57 PM   #8
my new 72
my new 72's Avatar
my sportsman II heads are 72cc. I like the higher comp, but you may want to run the 76cc heads to be able to run on the cheap stuff. Any world head is a good one though. They are just Darts in disguise. if you want more comp then go with the 72cc heads. Youll be right where I am at 10.2/1
Old 12-19-2002, 08:27 PM   #9
MikeB
MikeB's Avatar
World Products SR Torquer heads are not even close to Dart Iron Eagles in chamber design, intake port size choice, or flow numbers. However, I can not recommend Iron Eagles due to cobby castings and some other problems I've had. IMO, the SR Torquers are a much better casting, at least from a fit and finish standpoint, but they are not the same as Darts.
Mike
Old 12-19-2002, 08:33 PM   #10
crazy longhorn
Fabricate till you "puke"
Take a look at the edelbrock E- Tec 200's......they werent out 2 yrs ago when i did my stroker, but my bet is they will make some power......
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 12-19-2002, 09:01 PM   #11
mikep
mikep's Avatar
Has anyone run the Pro Action heads. Theyre flow numbers look really good. I understand theyre cast "Down Under" which would lead you to think of Australia .... But its not! Theyre actuallly cast in Argentina. I guess thats south of the equator. I haver a justified sneaking suspicion that World Products and possibly Dart ( WP and Dart WERE the same company once ) are cast at the same foundry as the Pro Action in Argentina and are sent here for machining and since over 50% of the value added work is done in the US they can call themselves US Made.
No truck :-(
Old 12-19-2002, 09:30 PM   #12
crazy longhorn
Dart & world products were the same company at one time.....till 2 guys had a difference of oppinion & they split. i cant say where they were cast , but had looked at the dart heads & was steered toward edelbrock by a trusted local shop for the reasons that Mike b mentioned. As far as fit & finish the Edelbrocks are good. The world products heads also look good......
Old 12-20-2002, 05:38 PM   #13
MikeB
MikeB's Avatar
Rumor has it tha Pro Action will release some very inexpensive iron heads in the future, as well as bare small blocks. I always thought they were in Australia, too.
Mike
Old 12-20-2002, 08:21 PM   #14
mikep
mikep's Avatar
http://proshaver.com/ProCatalog.pdf
http://proshaver.com/netspecial.htm
Theyre pricing is awesome and theyre flow numbers are pretty enticing. I might have to try a set on my next build.
No truck :-(
