Old 03-20-2009, 10:00 AM   #1
Storm Chaser
Storm Chaser's Avatar
3/4 ton "brake thingy"
On the rear axle of my 2wd crew cab, the flexible brake hose goes into a contraption mounted on the axle. It has some kind of pivot arm on it and also acts as the distribution to the rear brakes. It looks to me like the lever moves as the pinion rotates. My buddy's truck is a 3/4 ton (86 I think) and it has it also. However, my 76 3/4 ton doesn't have it and the 84 3/4 ton 4x4 I used to have didn't either. What is it and what does it do?
1988 R2500 Crew Cab
Immediate plans- get it running!
Future plans-
Rear disc swap & Hydroboost
Dually conversion with shackle flip-n-switch
4x4 conversion with 52" springs
Maybe some new body panels
Who needs a car when they make crew cab trucks?
Storm Chaser is offline   Reply With Quote
Old 03-20-2009, 11:14 AM   #2
red caddy
Re: 3/4 ton "brake thingy"
My '77 crew cab had one , as does my '86 1 ton. It's a load sensative brake bias adjuster. as you load the rear suspension, it allows more braking to be done by the rear brakes (drums) The idea is to not allow the rear drums to lock up if the truck is lightly loaded, but allow full pressure to the rear wheel cylinders, when the truck is fully loaded.
It's just a fancy barrel valve that reads load weight as a function of the changing distance between the frame and rear axel. BTW, disconnect the arm and fully open the valve when bleeding the rear brakes, (I learned this trick from an old GM shop manual) otherwise, you can chase an air bubble for days... RED
red caddy is offline   Reply With Quote
Old 03-20-2009, 11:50 AM   #3
dieseldr4
my 86 c30 has it too.. when the p.o. lowered the back, they left it alone, hence i got the truck with no rear brakes and the linkage and mount were wasted.. i bypassed it, my truck stops like it should and even with a couple "hold my beer" panic stops ive never had the backs lock up...i know out here these trucks are popular, so finding things like that is hard to do... btw , with a trailer loaded up to go racing with all my tools, equiment, stock car etc, it stops fantastic... hope this helps...
dieseldr4 is offline   Reply With Quote
Old 03-20-2009, 04:07 PM   #4
red caddy
My '86 1 ton SWB, narrow dually will lift the duals off the ground with a hard stab on the brakes, 'course there is almost no weight on the back right now, only the flatbed frame and the hitch receiver. The brakes are a little touchy on sandy or wet roads, but not scary. I don't drive it unloaded very much anyway. Finishing the bed, adding the genset, tool box and extra tankage will likely improve the braking around town though.
With the car hualer on and load leveler hitch, the old girl stops very well, (proportioner installed and properly adjusted) even in the rain. When I bought the truck, the PO had bypassed the prop and touching the brakes in a turn, on a wet or sandy road, empty, was a gay-ron-teed pucker factor spike... RED
Old 03-20-2009, 04:10 PM   #5
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
can you take a pic of it?
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 03-21-2009, 09:48 AM   #6
red caddy
Sorry Rusty, I ain't got near big enough stones to do that again, on purpose. That was not a "hey, hold my beer N' watch this" moment. I was tryin' not to kill a "nearly dead" snowbird in a Kia (with Jersey plates) that pulled a "swoop N' squat" in the fast lane on I-75. The front's didn't lock, but the duals did, and bounced hard, leaving palm sized contact patches 3 or 4 feet apart, for a long ways. Not something I want to do again for a you tube video. RED
Old 03-21-2009, 08:54 PM   #7
powerdriver 1958
Kid's Mechanic
powerdriver 1958's Avatar
do you see the part in this pic?
powerdriver 1958 is offline   Reply With Quote
Old 03-22-2009, 04:16 AM   #8
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
It should be on the frame.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 03-22-2009, 09:25 AM   #9
GM72K10
Next!
GM72K10's Avatar
I think this is what he's talking about. All K20s and C or K 30s should have these.
86 K30 CUCV M1028A1
86 K30 CUCV M1028a2 dually
86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump
More square bodies and CUCVs than I care to admit to
2020 Silverado K3500HD Work truck
GM72K10 is offline   Reply With Quote
Old 03-22-2009, 12:07 PM   #10
red caddy
I'm sorry, Rusty. I missunderstood your question, perhaps this pic will help RED
Old 03-23-2009, 02:27 AM   #11
Storm Chaser
Yea, that's what I'm talking about. Is there a year range they were used? I looked at my 76 again and it didn't look like it ever had one.
1988 R2500 Crew Cab
Future plans-
Old 03-23-2009, 03:12 AM   #12
78 Chevyrado
Does that valve take the place of a proportioning valve, or just work with it?
78 Chevyrado is offline   Reply With Quote
Old 03-23-2009, 03:45 PM   #13
red caddy
AFAIK, it was an "add on" with certain suspension packages, towing packages, fleet trucks, chassis cab's and so on. The front cross member mounted proportioner is stock on most all trucks, '60's and up. Every "hydraboost" equipped truck I' ve seen had the extra valve, but I've never seen a "hydraboost" on half tons either. RED
