Old 03-20-2009, 05:03 PM   #1
mainermikeyd
mainermikeyd's Avatar
700r4 4x4 swap
Scored a local tranny for sale out of a 85 4x4 k5 blazer, I ve read all the forums on the 350 to 700 swap, but doesn't seem to be much mention in a 4x4 with a NP205, any help guys??
Once a Marine Always a Marine OOH-RAH
GM Fanatic
1982 K20 4" Rancho lift 350cid, edelbrock performer intake 1405 carb, hedman headers, TH350, " Wheres the MUD!!!!!!!!!!"
1986 c30 camper special 454, th400 (for sale)
1984 K10 Big Ten (project) needs motor
1984 C10 355, 700r4, (project) needs shortbox bed
mainermikeyd is offline   Reply With Quote
Old 03-20-2009, 07:00 PM   #2
sdavid
sdavid's Avatar
Re: 700r4 4x4 swap
NP 205 never came behind a 700R4, so you will need an aftermarket adapter. Maybe Advanced Adapters makes one. Then you will need to modify both driveshafts. I think your front will be too short and rear too long. Then you will have to modify the cross member that the tranny and transfer case bolts to or at least move it's location to fit the new combo.
It can be done and has been done, but it takes some work to do it.
'81 C10 Stepside, SBC, T350, Wood Bed, and silverado options
'87 K5 402 BBC, T350, 3.73s locked up, 2.5"Lift, 33x12.50x15s
sdavid is offline   Reply With Quote
Old 03-20-2009, 08:17 PM   #3
rockn30809
Re: 700r4 4x4 swap
That is a pricey adapter kit. Last one I saw went for almost $500.00 and you have to change the output shaft in the transmission.
rockn30809 is offline   Reply With Quote
