03-22-2009, 04:24 PM | #1 |
72 2wd lift?
I have a 72 C20....I really want to do a 4x4 conversion. Unfortunatly, funds wise it will take me a while to pull the funds together to to the four wheel drive thing, so........does anybody know of any way to do a lift on a 72 C20, relatively affordable?
03-23-2009, 11:43 PM | #2 |
Happy to be here
Re: 72 2wd lift?
Have you considered a body lift?
03-25-2009, 07:43 PM | #3 |
Re: 72 2wd lift?
Not a fan of body lifts at all, the looks of the, jacking steering angles up....just can't stand them.........
03-26-2009, 11:30 PM | #4 |
Re: 72 2wd lift?
One way to accomplish i lift on these 2wd is to lower the cross member, i ran across a a early 60's truck done this way yesterday, i talked to the owner and he said that it rode just like before just took some time to fabricate. Im going to swing by a take some pictures of it tomorrow night on my way home and then ill post them up to show you what he did.
03-29-2009, 07:47 PM | #5 | |
Re: 72 2wd lift?
I knew of someone who lowered the crossmember but the steering geometry was off. They took two idler arms and placed a block of steel in between to make up the 3 inch difference, however to clear the crossmember it actually shortened the throw of the pitman arm, thus making the turning radius very short. (he couldn't make a 3 point turn, it was more like a 5 point turn) \ thanks
www.cardomain.com/id/pooz911 |
04-05-2009, 04:34 PM | #6 |
Re: 72 2wd lift?
bump......
Any luck on those pictures???
03-27-2009, 11:31 AM | #7 |
Re: 72 2wd lift?
Right on and thank you. I figure that the suspension on these trucks hasn't changed a whole lot until you get to the early 2000's, so there has to be a way, even if it's mix matching parts. I'm starting to think that if it's going to become expensive that I might as well switch it to four wheel drive........
03-28-2009, 07:59 PM | #8 |
Re: 72 2wd lift?
3 inch body lift, suspension lift and 33 inch tires.
03-28-2009, 08:24 PM | #9 |
Happy to be here
Re: 72 2wd lift?
Sweeet!
03-29-2009, 04:03 PM | #10 |
Re: 72 2wd lift?
still trying to get those pics the guy hasnt been home when i have gone by with the camera.
03-29-2009, 06:30 PM | #11 |
Re: 72 2wd lift?
How did you get the suspension lift on the blue truck? and is there a gap above the rear bumper from the body lift?.....I am interested in the crossmember lift, I'm assuming this is something I can do at home with a welder and material, is a tubing bender needed? Thanks guys
03-29-2009, 07:40 PM | #12 |
Re: 72 2wd lift?
The front suspension is lifted by Rancho Springs, 1 inch upper ball joint spacer and the rear is completely stock (including the original shocks). the front frame horns were cut and moved up 3 inches, braced and welded back up. The rear bumper brackets was moved up and bolted/welded in. I am not using the ball on the bumper. I had a drop hitch welded into the frame for all of my towing needs. If you need, I can post some pictures of the back
www.cardomain.com/id/pooz911 Last edited by pooz911; 03-29-2009 at 07:42 PM. Reason: added more info |
