03-24-2009, 12:39 AM | #1 |
1987 k10 brakes on a 66 c10
i just got these brakes from pick apart and i was wondering if anybody can show me some pick or show me a diagram of how the brake tubing would run starting from the perportioning valve, which goes where. I would appreciated if somebody showed me. Thanks
03-24-2009, 12:48 AM | #2 |
60-66 Nut
Re: 1987 k10 brakes on a 66 c10
Are you converting to discs on the front as well? are you using the '87 K10 master cylinder and booster?
03-24-2009, 09:52 PM | #3 |
yes im going disc in front, and im using the master cylinder and booster from the 87 k10 I also got the callipers from the 87. im disc brakes in front and the 66 drums in the back. i need to which way the tubing goes from the perportioning valve.
03-25-2009, 01:08 AM | #4 |
60-66 Nut
Here's a pic of one another member just did....see if this helps you out.
http://www.67-72chevytrucks.com/vboa...&postcount=117
