Old 03-24-2009, 05:43 AM   #1
Hoffman65burb
Hoffman65burb's Avatar
Exhaust kits
anyone used the exhaust kits from LMC, magnaflow, or summit? how was the installation? which was the best?
1978 GMC Jimmy
454bbc
Turbo400
NP205
3.73 gears
4inch lift
33's
Hoffman65burb is offline   Reply With Quote
Old 03-24-2009, 06:13 AM   #2
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Re: Exhaust kits
Subscribed.......
Hottrucks is offline   Reply With Quote
Old 03-24-2009, 06:16 AM   #3
Shock_Me
Shock_Me's Avatar
Re: Exhaust kits
We used the Magnaflow kit on a short stepside. It's made for a long box, so you have to do a little cutting at the header collector, but not too difficult. Installation is pretty straightforward with very good quality hangers. Also had to do a little fab work around the Early Classic Super Track bar in the rear. The truck is dropped 6" in the back, so the exhaust was rubbing on the track bar.
Has a nice mellow idle, with a good growl when you get on the pedal.
Totally stainless as well. Can't comment on the other kits, but I see even Thrush has a kit for these trucks now.
Pete
Shock_Me is offline   Reply With Quote
Old 03-24-2009, 06:24 AM   #4
Ace in the hole
Re: Exhaust kits
I have the LMC duals kit on my 4x4. It's actually made by heartthrob. I did not have any problems with it and the install was easy.
1970 K20, 350--- SOLD
05 silverado extended cab short box- duramax
Jeep wrangler unlimited
Ace in the hole is offline   Reply With Quote
Old 03-24-2009, 03:27 PM   #5
crapy67
White wall terror
crapy67's Avatar
Re: Exhaust kits
I used the Hooker Headers kit form Jegs, 2.25 inch pipes. The kit came with no mufflers so I got a set of flow master 40 series and couldn't be happier. The passenger side head pipe was in need of a little adjustment but nothing major. I would definitely recommend.
crapy67 is offline   Reply With Quote
Old 03-24-2009, 05:19 PM   #6
GMC3
Re: Exhaust kits
I just finished mine this weekend. i bought the heartthrob kit also and i know a lot of guys on here didn't have any problems with the install (i looked into it before buying it). I was really unhappy with the kit, If i didn't cut and weld to adjust some of the bends, the kit would have been useless to me. I bought the kit with the straight out the back dumps, and the pipes fit so poorly, and i had already modified it so much, I made them into dumps that dump in front of the rear axle. I'm actually happy with the way it looks now, really clean, nothing visible, but it was a real pain
GMC3 is offline   Reply With Quote
Old 03-24-2009, 06:54 PM   #7
Husker
Husker's Avatar
Re: Exhaust kits
Same Here No problems
Ron
Member #111
68 C-10 Daily Driver
70 4x4 Project
76 Jeep CJ-5
Help Support the Board:
http://67-72chevytrucks.com/vboard/payments.php
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors.
Thomas Jefferson
Husker is offline   Reply With Quote
Old 03-24-2009, 11:18 PM   #8
pmpski_1
pmpski_1's Avatar
Re: Exhaust kits
I used the Hooker kit from Summit. Driver side fit great. Passenger side didn't. Waaay off. I ended up going to a muffler shop to get it to fit right on my 71 C20.
On the flip side, I had the same Hooker kit work perfectly on my 76 Blazer. I mean Perfect.
Unless you're really strapped for cash or you've done a lot of exhaust work I'd just take it down to Joe at the Muffler Shop and get it done right for a tight fit. I bet you get a bunch of replies for this thread where the same kit fit great or like s**t on the same truck for different folks.
pmpski_1 is offline   Reply With Quote
