Old 03-26-2009, 10:02 PM   #1
sixty-eight shorty
sixty-eight shorty's Avatar
Talking 22inch wheel back spacing on a 2wd blazer?
is it possible to run 22 x 9 inch wheels with 5 1/2 back spacing on my 1971 2wd blazer ? i want to order 22 inch gun metal c-5's tomorrow . so if anybody can help me out i will greatly appreciate it . thanks in advance, frank
sixty-eight shorty is offline   Reply With Quote
Old 03-26-2009, 10:21 PM   #2
OARNGESI
OARNGESI's Avatar
Re: 22inch wheel back spacing on a 2wd blazer?
I think frizzle fry has them on his tahoe project they should be the same from blazer to suburban
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 03-26-2009, 11:15 PM   #3
sixty-eight shorty
thanks, OARNGESI . can anyone else help me ? if i get a couple more positve reponse i will definitely be buying them tomorrow . thanks,frank
Old 04-26-2009, 04:12 PM   #4
clos69
Its Topless Season!!!!
clos69's Avatar
Hey Frank...here are the pics ,now all you need is to lower it a bit and that sucker will look even sweeter
-Carlos-
The of America
1967 SWB Custom C-10 (Celeste)
Join the Patina Club
clos69 is offline   Reply With Quote
Old 04-26-2009, 04:20 PM   #5
Frizzle Fry
Frizzle Fry's Avatar
Yes, I run the C5 22x9 w/5.5" BS but be aware that they rubbed my tubs until I mod'ed them. This is partially due to the big rubber I went with: 305/40/22. Also, the Blazer/truck tubs/wells are not exactly the same as the Burbs, but are likely the same width. The bottom line is, depending on how low you want to go and tire selection, you may have to play with spacing and/or tub mods.
Frizzle Fry is offline   Reply With Quote
Old 04-26-2009, 05:44 PM   #6
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
It probably will make a differance if you plan on lowering it with
springs vs. bags also. (Not an expert on this but what I heard)
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 04-27-2009, 06:38 PM   #7
sixty-eight shorty
Talking Re: 22inch wheel back spacing on a 2wd blazer?
thanks clos69 , for posting pics of my blazer . i am going to lower it a.s.a.p . frizzle fry , i went ahead and bought 22 's with 5 inch back spacing for the rear and i went with 5 1/2 inch back spacing for the front . from the looks of it, i think i will have enough room in the rear for my wheels . i also went with 265/35/22 tires so that i could be able to go a little lower . i plan on lowering it with 3 inch drops springs in the front and 2 inch home made lowering blocks that clos69 gave me . thanks for everyone's help . frank
Old 04-28-2009, 05:27 PM   #8
r1lorenzini
i have 265/35's on mine wiht no problem int he back. but 2 inches in the rear is nothing here is mine with a 5 inch rear
r1lorenzini is offline   Reply With Quote
Old 04-28-2009, 05:33 PM   #9
sixty-eight shorty
does your blazer go any lower when you put your top on ?
Old 04-28-2009, 05:30 PM   #10
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
I know it's 22's all the way around, back is 5" so what is the front?
Old 04-28-2009, 05:35 PM   #11
sixty-eight shorty
if your refering to me , i have 5 1/2 inch back spacing in the front .
Old 04-28-2009, 05:49 PM   #12
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
No, I was hijacking sorry, wanted to know how low his front was.
Old 04-28-2009, 06:00 PM   #13
sixty-eight shorty
no problem LUV2XCLR8 , i would also like to know what drop he has in the front ! frank
Old 04-28-2009, 06:41 PM   #14
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Just hoping I didn't go to far with mine
Old 02-16-2011, 08:33 PM   #15
exploderjim
exploderjim's Avatar
Can you run the same 5 inch back spacing in the front as well? Or does it need to be different? I wanted to order the Black Chrome in 22's.
exploderjim is offline   Reply With Quote
Old 02-16-2011, 09:08 PM   #16
lolife99
67-72 parts collector,…
lolife99's Avatar
If you are using a 22x9,... I would run the 5.5" BS on the front.
If you are using a 20x8.5,... go with the 5.25" BS on the front.
Keith
Convert to disc brakes.
Old 02-17-2011, 07:55 PM   #17
exploderjim
Correct it will be 22x9 front and back. Thanks for the advice.
Old 02-17-2011, 10:31 PM   #18
lolife99
lolife99's Avatar
I would run the 5" BS on the rear and the 5.5" BS on the front.
Keith
Old 02-18-2011, 09:33 AM   #19
exploderjim
Thanks. I'm going to be running air in the front and back with a bolt in notch in my Blazer so I wanted to make sure which ones to order. Thanks again Lolife99. Not to highjack this thread to much but would you suggest what type or make of bags to use? I'm going to use the Accuair set up but I still have to buy the bags for the front and back plus the install kits for the front. I will be using new bag trailing arms for the back. Any advice would be appreciated.
Jim
