Old 03-27-2009, 06:59 AM   #1
69c10step
69c10step's Avatar
Original ride height?
Does anyone know the measurement from the center of the axel to the top of the wheel arch? I've seen measurements of 32"/front & 34"/ back as measured to the ground, but that is assuming stock wheels and tires.
'69 short step with dreams of being a hot rod
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
69c10step is offline   Reply With Quote
Old 03-27-2009, 10:23 AM   #2
see ten
WTB this ad
see ten's Avatar
Re: Original ride height?
Early Classic claims their 6" drop rear coil will leave 3" between the frame and axle tube. From that statement I assume that a new stock height coil would be in the area of 9" between the frame and axle tube. No idea what the front would be.
You're on the right path checking from the center of the wheel to the fender lip. That's the only way to get a good mesurement that disallows tire size variances.
see ten is offline   Reply With Quote
Old 03-27-2009, 11:02 AM   #3
69c10step
69c10step's Avatar
Thanks SEE TEN....that's a starting point.
Old 03-27-2009, 11:58 AM   #4
67ChevyRedneck
67ChevyRedneck's Avatar
I actually did this a couple months ago and wrote it all down.
For the front I have ~31-3/4" up front from the ground to the wheel lip and ~18-1/2" from the center of the wheel to the fender lip.
For the rear I have ~33-7/8" and ~19-3/4" respectively.
They varied a little from side to side so I took the average of the two front and two rear measurements to get what I posted.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 03-27-2009, 12:28 PM   #5
69c10step
69c10step's Avatar
Thanks Jesse, that was what I needed.
Old 03-27-2009, 03:28 PM   #6
project 67 sub
project 67 sub's Avatar
whats the hight of the original tires though?
project 67 sub is offline   Reply With Quote
