03-27-2009, 03:29 PM | #1 |
What mufflers are you guys running?
I bought my 76 with flowmaster 40 series and they sound good but are a bit loud. Not to mention the drone that flows have... (no crossover yet but would like to get one installed however the driveshaft is in the way except at the rear axle) I thought about 50-60 series but if I'm gonna pay for new mufflers, it'd be silly to get the same brand if the drone bugs me. I thought about magnaflow but basically the design I saw was a straight through perforated pipe inside a "regular" looking case, so it's a glorified cherry bomb with more packing.
Basically looking for info about what you guys run and if you'd buy them again? Also, anyone seen a good comparison in a magazine or on a website between several different brands? thanks Last edited by maxreps; 03-27-2009 at 03:31 PM. |
03-27-2009, 03:36 PM | #2 |
Re: What mufflers are you guys running?
I'm currently running flowmasters on my '74 too and you do get tired of all the noise after a while. I'm thinking of switching to a turbo muffler i hear they're not as loud. I have a buddy that has a borla on his 2004 silverado with no cats and it sounds good i like it but borla is expensive.
03-27-2009, 03:59 PM | #3 |
I run Flowmaster 50 series Delta Flows. It's that Flowmaster sound, but turned down a notch and without the drone. In my setup, I have long tube headers, an H pipe, and the pipes exit under the rear bumper.
Not sure what your setup is, but if the exits are dumped right under the vehicle, this is a recipe for LOUD. The sound bounces around between the pavement and the underside of the vehicle and it end up being louder than it should. This also increases interior resonance by a good bit too. Magnaflows are basically a better turbo muffler. Construction and muffling are the same, but instead of the "S" path, it's straight through. These are quiet at cruise and idle, but at full throttle they are pretty loud.
1977 GMC Sierra Grande Last edited by Pyrotechnic; 03-27-2009 at 04:00 PM. |
03-27-2009, 04:09 PM | #4 |
I've got Hooker Aero Chambers on my big block. Nice mellow tone at idle, no noticable drone at cruise, get comfortably loud at WOT.
http://www.holley.com/types/Aero%20Chamber.asp http://www.holleytv.com/video_detail.php?mId=1598
- Greg |
03-28-2009, 12:32 AM | #5 | |
Planning on running a Dynomax Bullet on the K5 |
03-28-2009, 03:39 AM | #6 |
Go Hard or Go Home!
40 series flowmasters, dumps LOUDLY right behind the cab.
75 short wide 350, some mods, scare the piss outta ya quick. 2008 Dodge crew cab. YEAH, it's got a hemi, your ass is going to jail quick. Some day's, it's just not worth chewing through the restraints................................ |
03-27-2009, 04:11 PM | #7 |
Right now it's running stock manifolds(just bought a set of flowtech headers) and is 2.5" running all the way past the axle exiting on each side(pointing down but not near the ground-can't be seen from the rear) right behind the rear tires.
Haven't thought about Corsa.. I'll look into them. I have ran the Dynomax super turbo on my 71 240z, it was loud but prob is quieter than my 40's are now. Last edited by maxreps; 03-27-2009 at 04:12 PM. |
03-27-2009, 04:28 PM | #8 | ||
I have a corsa system on my 03 silverado and think its one of the best exhaust systems out there, IMO. And I have read that they make a universal style muffler, and have seen them on the jegs website...... http://www.jegs.com/p/Corsa/964933/10002/-1 I'm pretty sure they make them for a larger diameter exhaust as well.
74 GMC SWB Project "Sin-thia" Static Dropped 8"f/10"r http://67-72chevytrucks.com/vboard/s...d.php?t=460030 97 GMC reg cab short bed, 4.3V6 / 5spd, daily driver 220,000 miles, all stock for now |
03-27-2009, 05:49 PM | #9 | |
I don't think these pills work
SQUARE84 90 SUBURBAN |
03-27-2009, 06:35 PM | #10 |
I am sure that the setup doesn't help things either since I cruise at 3100-3200 rpm @ 60mph... I really need to put in a 700R4! I've calculated that'd put me about 2200 @ 60mph.
03-27-2009, 04:19 PM | #11 |
has any one bought any of the cheap ebay dual muflers ? High Performance 2 Chamber Muffler 2.5" C/ 2.25" DUAL,[ Item number: 330317195348] or a OBX Muffler KV5014 Dual-in Dual-out ? [ Item number: 170314912375 ]
if so do they sound good ? |
03-27-2009, 03:46 PM | #12 |
I have the Summit 2 1/2" Turbo mufflers on my '85. They're the $17 mufflers in the catalog. They sound pretty good but when I redo the truck this summer I'm going to put 50 series Flowmaster's on it.
If I want to cruise qiuetly, I'll just drive my honda.
'69 Dodge Charger R/T 440, 727, 3.55 Sure Grip '68 Plymouth Road Runner 383, 727, 3.23 Sure Grip '89 Dodge Diplomat ex cop car 408, 727, 3.55 Sure Grip '77 Dodge Monaco ex cop car 440, 727, 2.71 '79 Dodge 'Lil Red Express pickup 360, 727, 3.55 Sure Grip '12 Dodge Challenger SRT8 392, M6, 3.92 '85 Chevrolet C-10 SWB 2wd 305, TH350, 2.73 |
03-27-2009, 03:49 PM | #13 |
US Army Veteran
Not quite at that stage yet, but probably going to run Corsa. I had them on a C5 Corvette years ago and they sounded great at wot and very quiet at cruising speed (have noise canceling technology to get rid of that drone).
Don't think they make them specifically for our trucks, so will probably find a system on Ebay to chop the mufflers out and have them custom done at an exhaust shop.
1972 C10 Highlander - The making of a daily driver |
03-27-2009, 05:05 PM | #14 |
On my 85 I'm running two cherry bomb extremes (1 chambers) turned down before the axle. It sounds great and is very loud, both inside and outside, but I dont care, I'm a kid and it doesnt bother me. If you want it quieter than I would reccomend Maganflow or Hooker's Aerochambers. They both have a more "mellow" tone but still sound great.
03-27-2009, 05:11 PM | #15 |
i always use 2 1/2" in/out 40 series flowmaster mufflers b/c i like the agressive tone myself
i got a truck awhile back that had two turbo mufflers on it, they sounded good though, but i had to take them off to put on some FM's
1987 350 TBI lowered 5/7 |
03-27-2009, 05:19 PM | #16 |
Resident of Here
My 84 has stockers on it, but will get a custom 3" with a diesel muffler later this year.
~Bradley~ 2004 Black GTO LS2/T56 too much to list Miss having a truck |
03-27-2009, 05:26 PM | #17 |
50 series flowmaster delta flow and an x pipe. still sounds like flowmasters but no real quiet in the cab.
03-27-2009, 06:31 PM | #18 |
I ran 2.5: spntechs on my car... never droned well at least less than my blowmaster 50's... it was dumped too..
but I'll be running 3" ones on the truck... they sound good.. |
03-27-2009, 06:36 PM | #19 |
03-27-2009, 10:08 PM | #20 |
03-27-2009, 10:38 PM | #21 |
Single 3" w/40 series Flowmaster & no cat!
03-27-2009, 10:55 PM | #22 |
My black truck is running a 2.5" dual exhaust that exits behind the rear wheels . It had 40 series flows but I switched it to 50 series . I like the sound better now . The 40's were OK but not for this truck . I will probably run 40 series on my next truck because it wont be a stock engine cruiser .
Frank
Born and proudly residing in a Red State ! Last edited by f.monroe; 03-27-2009 at 10:55 PM. |
03-27-2009, 06:46 PM | #23 |
I have flowmaster 40's on my truck and they are loud! THey are dumped under the truck and they suck. Makes the whole truck vibrate at certain RPM's.
I am going to try and find a muffler called Mello Tone. I have had some before on a old buick and it sounded great and made a noticeable difference over stock. I don't live near the shop that sold them and haven't found them online.
82 Chevy SWB "OrangeAnimal" Lot of Goodies! Sold 93 GMC 1500 "Angry Red" 383 TBI Powered Fun! 300hp/410ft.lbs. 09 Yaris wife's daily. Last edited by OrangeAnimal; 03-27-2009 at 06:49 PM. |
03-27-2009, 07:50 PM | #24 |
i have flowmaster original 40's.i wanna be loud and obnoxious.i have the cab dynamatted big time.so,i don't notice the droan,plus i'm hard of hearing from 31yrs of working in the paper mill.so,it all work's out.
" Never look up a dead dogs butt." |
03-28-2009, 10:44 PM | #25 | |
RAT1968 '68 Cab/'71 Parts
I'm a fan of Flowmasters. But, then again, the truck is not my primary transportation. When we go off into the sunset, we take the wife's Japanese car.....I think she's running Nissan Morano exhaust. If I'm tripping around by myself, I drive the Jeep. Six banger geared to drive up a flagpole, and get out of the way of faster traffic once I'm up to highway speed. Works for me. Nothing's as good as driving the truck......You guys know that. Well, I guess if I had a 34 Ford Vickie with a 350/700R/air/electric windows, satellite radio, etc......
M17 Coarsegold, CA RAT's shiny now. But always a rat. Last edited by magwakeenercew2jh; 03-28-2009 at 10:56 PM. Reason: Add a small pic |
