Just like to part out trucks!!
A 70 GMC now
This is a 70 GMC C20, I will be parting it out as usual
![]() Exhaust manifolds $50 plus shipping for pair-SOLD 4 speed high hump $25 plus shipping 4 speed steering column $40 plus shipping-SOLD V8 motor stands $30 shipped Good radiator support, $50 sale pending metal door panels, drivers has a couple small dings and a ring where the window crank rubbed, pass is is beat up bad $10 plus ship See anything else you may want ask and I'll price, Thanks Randy
67 Chev swb stepside 4x4 283 4 speed SOLD 72 blazer 4x4 4 speed Cheyenne 72 GMC swb 4x4 fleet 4 speed, original paint 1958 Cameo (one of 1405 built, it was my dads) 2020 chevy Apex 4x4 crew cab 1969 Z28 with the 302 1980 chevy swb 4x4 1964 chevell Malibu SS 1976 K20, sold new originally out of my dads chevy dealership Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure" Last edited by teeitup; 04-01-2009 at 08:57 PM. |
Redefining LowBudget
Re: A 70 GMC now
would you consider clipping the header pipes out ( not the rams the acual pipes) with the clamp ring?? the E brake cables,and I need a upper radiator support hold down for a 4 core I have a 70 I'm trying to put together on a low budget
thanx jeff
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. ![]() Mikes Sandwich Fair Run OCT 8th 2011
Re: A 70 GMC now
Randy,
I need a passenger door. I know you normally don't ship the heavy and or big parts, but I need a right door. Kerry
1969 Chevelle 1990 IROC Z Convertible 2002 Silverado LT |
Re: A 70 GMC now
Hottrucks, how much of the exhaust pipes you needing? Sorry it doesn't have any E-brake cables on it. No upper 4 core mounts, I'll look and see if the lowers are there.
Wootdog, Kerry, sorry I still don't mess with shipping doors Thanks Randy
67 Chev swb stepside 4x4 283 4 speed SOLD 72 blazer 4x4 4 speed Cheyenne 72 GMC swb 4x4 fleet 4 speed, original paint 1958 Cameo (one of 1405 built, it was my dads) 2020 chevy Apex 4x4 crew cab 1969 Z28 with the 302 1980 chevy swb 4x4 1964 chevell Malibu SS 1976 K20, sold new originally out of my dads chevy dealership Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure" |
![]() Join Date: Jan 2007
Re: A 70 GMC now
how much would shipping on the 4spd column be to Va. 23061? thanks
ASE MASTER TECH
Re: A 70 GMC now
Do you have these two parts? They are the Steering column front and support plates.
Blazer Project Last edited by gottwake; 03-28-2009 at 12:55 AM. |
Re: A 70 GMC now
randy I would take as much as it has or is easy to get out I'm going to have to build a full exhaust anyway..I need the steel plate that hold the rad not the rubber so much..and the splash well from the drivers side bed ( THE LITTLE PART FROM THE WHEEL WELL TUB TO THE BOTTOM OF THE FENDER) sorry caps) \
I'm just tearing into this so I may need more stuff as I get though today thanx jeff
"the other guy"
Re: A 70 GMC now
i need the ignition switch spacer shipped to 95901? thanks
God Said,"Building A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still....."EXPLETIVE" ![]() |
Re: A 70 GMC now
bad421, I'll get a quote this weekend for you
gotwake, Yes I have both of those $20 shipped for pair, I know I have the four lower bracket bolts, but unsure if I have the upper one, but I'll look Hottrucks, Jeff, I can cut it past the bend no problem $15 for pair, the upper 4 core brackets are not there, sorry. The bed splash pan is $10, so $25 plus shipping for what your asking about? vasquezmrysvll, sorry it doesn't have a key in it for me to pull the ig switch. I could cut the whole switch out for you. $15 shipped? Thanks let me know guys, I'm not going to be able to do much today, Sleeting, snowing and Wind is BLOWING hard today, Randy
Active Member
![]() Join Date: Feb 2000
Re: A 70 GMC now
Randy=
How are the headlight trim rings? Shipping to 21157? Thanks!
68 short fleet 383 stroker, 700r4 373:1 posi 72 GMC 3/4 ton- weekly driver 700r4 351;1 posi |
Re: A 70 GMC now
I'll have to check them out, I never looked at them. It will probably be Sun befoer I get out there. Thanks Randy
Re: A 70 GMC now
thanx T cut it as far back as you dare and I'll take the splash pan too
let me know what shipping is I'll pm you my addy thanx Jeff
Re: A 70 GMC now
Hottrucks, Jeff, it will probably be Mon after work before I get out there to cut them off. Thanks Randy
Re: A 70 GMC now
no biggie I'm not in a big rush
#15 |
Re: A 70 GMC now
Randy, if the dash isn't cut I am interested in the dash around the radio and ac.
#16 |
Re: A 70 GMC now
I think I may end up being out there today pulling a motor out of the 68, I'll try to look at everything everyone has asked about and hopefully have time to get some of the parts off.
Stope, this truck doesn't have AC on it? Wan't sure if you were needing one with AC or not? Thanks Randy
67 Chev swb stepside 4x4 283 4 speed SOLD 72 blazer 4x4 4 speed Cheyenne 72 GMC swb 4x4 fleet 4 speed, original paint 1958 Cameo (one of 1405 built, it was my dads) 2020 chevy Apex 4x4 crew cab 1969 Z28 with the 302 1980 chevy swb 4x4 1964 chevell Malibu SS 1976 K20, sold new originally out of my dads chevy dealership Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure" Last edited by teeitup; 03-29-2009 at 10:04 AM. |
#17 |
Re: A 70 GMC now
Curbstone, the driver side has a dent in lower middle and one on the outside lip and some surface rust, pass looks OK. $12 plus shipping for pair
Hottrucks, got your stuff off but I need to get a box to figure shipping, I'll do that Mon after work. Stope4, its in good shape $15 plus shipping Thanks let me know guys, Randy
67 Chev swb stepside 4x4 283 4 speed SOLD 72 blazer 4x4 4 speed Cheyenne 72 GMC swb 4x4 fleet 4 speed, original paint 1958 Cameo (one of 1405 built, it was my dads) 2020 chevy Apex 4x4 crew cab 1969 Z28 with the 302 1980 chevy swb 4x4 1964 chevell Malibu SS 1976 K20, sold new originally out of my dads chevy dealership Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure" Last edited by teeitup; 03-29-2009 at 09:06 PM. |
#18 |
Re: A 70 GMC now
need one with ac. thanks
#19 |
![]() Join Date: Jun 2007
Re: A 70 GMC now
Grille, surrounding trim and core support?
Condition of those and prices please. I'd pick up instead of shipping. |
#20 |
Re: A 70 GMC now
t hold up a sec I just bought a parts truck yesterday so I need to se what it has on it I'll be picking it up wed eve
thanx Jeff
#21 |
Re: A 70 GMC now
stope4, I'll have one coming in a truck next week
MonteSS454, grill and surround is all dented up. Core support is pretty decent, I'll get pics later today of it all, $50 for it. Hottrucks, thats fine just let me know Thanks Randy
#22 |
Re: A 70 GMC now
Ok, thanks if the core is as good as you say I'll be pming you.
#23 |
Re: A 70 GMC now
Monte, here are some pics, part of the inner fender is still bolted to it on both sides. It has one spot where there is rust, see pic, it is not through. The area below the battery tray on the bottom side is pitted but not rusted through. Thanks let me know, Randy
1) whole support 2) drivers side top 3) driver side bottom 4) pass side top 5) Pass side bottom
67 Chev swb stepside 4x4 283 4 speed SOLD 72 blazer 4x4 4 speed Cheyenne 72 GMC swb 4x4 fleet 4 speed, original paint 1958 Cameo (one of 1405 built, it was my dads) 2020 chevy Apex 4x4 crew cab 1969 Z28 with the 302 1980 chevy swb 4x4 1964 chevell Malibu SS 1976 K20, sold new originally out of my dads chevy dealership Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure" Last edited by teeitup; 03-30-2009 at 09:40 PM. |
#24 |
Re: A 70 GMC now
Here is the small rust area
#25 |
Re: A 70 GMC now
More parts
