Old 03-29-2009, 11:13 AM   #1
mjensen
mjensen's Avatar
It actually runs!!!!
Well, I was able to make some good progress this weekend. It starts and runs like a champ! It is missing a bit under load, so I hope to go out and check the ignition system today.
The way it should be
Name:  the way it should be.jpg
Mike
'69 GMC 3/4 ton 4x4 Build Thread
mjensen is offline   Reply With Quote
Old 03-29-2009, 11:22 AM   #2
Andy4639
Old member
Andy4639's Avatar
Re: It actually runs!!!!
Nothing like getting something to work on your own. Feels good don't it!
Nice trucks you have there, That GMC looks right at home in the garage.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 03-29-2009, 11:46 AM   #3
68gmsee
Active Member
68gmsee's Avatar
Great going! Another old truck brought back to life... I bet the neighbors ain't too pleased, though.
I had one call the city on me cause I had my old 69 parked in the driveway unlicensed. Had to move it out to my country property.
68gmsee is offline   Reply With Quote
Old 03-29-2009, 11:48 AM   #4
mjensen
mjensen's Avatar
My neighbors are actually pretty cool. One of them said "let's go around the block". Of course what do you do? We went around the block...a few times
Mike
Old 03-29-2009, 11:53 AM   #5
Boog
laying low
Boog's Avatar
Good neighbors you have there.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 03-29-2009, 12:20 PM   #6
mjensen
mjensen's Avatar
I do have a question about the miss. It still has points, and I'm only familiar with the points systems in VWs. Do they slowly go out, or is it an all or nothing thing?
Mike
Old 03-29-2009, 03:04 PM   #7
dan42
dan42's Avatar
Consider trading out the dizzy for an HEI unit - huge upgrade at a small price. I got a new one on Ebay for around $75.00.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 03-29-2009, 04:21 PM   #8
mjensen
mjensen's Avatar
I actually have one from my brother-in-law's 400 SB. I just bought a new cap, rotor, and coil for it. So I may just swap it out.
Mike
Old 03-29-2009, 04:27 PM   #9
spinning wheels
spinning wheels's Avatar
Before you install the HEI, read some of the post on this site. You will need to get 12 volts to the dist. The stock set up only has 12 volts when you start it, then drops to 7 1/2 volts. With this low voltage, you will fry your module in the HEI.
It is not rocket science, and someone with limited knowledge of car electronics can do it, (like me).
Oh yeah, did your give you the spark plug wires?
'72 GMC custom camper 350/350
spinning wheels is offline   Reply With Quote
Old 03-29-2009, 04:29 PM   #10
mjensen
mjensen's Avatar
No, I was going to replace the plugs and wires as well when I do this. I've been searching for tips on this swap. Is there an FAQ on this?
Mike
Old 03-29-2009, 04:33 PM   #11
spinning wheels
Not sure about FAQ, but there should be a few posted threads. Just do the google search, at the top of the page.
I learned about this problem the hard way, by frying an MSD module and had to have the truck, flat bedded home. That was about a $120 lesson
