Old 03-29-2009, 04:23 PM   #1
americanmusc1e
americanmusc1e's Avatar
Is this a common problem?? or am I a bad driver???
drivers side rear
shocks are rancho RSX
It broke the bolt once before and I put a good Grade 8 bolt in there and it broke the mounting tab as you see here.
Could I have the wrong size shocks???
I do drive down a lot of rough roads
-- Josh
Instagram: @americanmusc1e
OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread
FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread
1999 4wd OBS Tahoe - daily.
DM me if you can't see photos i posted
americanmusc1e is offline   Reply With Quote
Old 03-29-2009, 04:27 PM   #2
project 67 sub
project 67 sub's Avatar
Re: Is this a common problem?? or am I a bad driver???
one of the ones on my burb were like that when i got it, so i replaced it with a new one and drilled the holes out slightly larger and installed the shock studs like on the top in the front
project 67 sub is offline   Reply With Quote
Old 03-29-2009, 04:28 PM   #3
Chevymann1968
Chevymann1968's Avatar
WOW Ive never seen that before!!!!
1968 GMC
Rebuilding Stage
2001 Camaro SS SOLD
Chevymann1968 is offline   Reply With Quote
Old 03-29-2009, 04:30 PM   #4
nds1968
nds1968's Avatar
Are you sure your shocks aren't to long and bottoming out.
Nate
1967 short fleet Project Blue Goose
'If it don't bounce back... heeheehee you go hungry!" Blues Brothers
nds1968 is offline   Reply With Quote
Old 03-29-2009, 04:33 PM   #5
americanmusc1e
they're supposed to be right but I'm beginning to wonder....... anyone else running Rancho RSX 1000's???
-- Josh
Old 03-29-2009, 04:33 PM   #6
big_al_71
big_al_71's Avatar
I cant say I ever seen that before till today...
I agree with the comment about your shock being too long though.
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 03-29-2009, 04:42 PM   #7
Lugnut64052
Middle-aged Curmudgeon
Lugnut64052's Avatar
I just replaced the driver's side mount on my '72. It was almost like that-- the hole was beat out pretty bad but not quite broken. The other side looked perfectly normal.
That bolt in the picture looks pretty small. I'm thinking mine took, like, 7/16-inch, or something pretty big.
Bret
Check out the site's Truck Tech FAQ.
Be a site supporter.
My more-or-less pathetic build thread.
Board members I've met:
Longhorn Man
Dieselwrencher
jholley
big mike71
Lugnut64052 is offline   Reply With Quote
Old 03-29-2009, 05:34 PM   #8
Green Machine
Green Machine's Avatar
Pretty sure that takes a 1/2 inch bolt, 3/4 inch wrench size. Either the bolt worked loose, was too small or both.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 03-29-2009, 06:06 PM   #9
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
I would think your shock is to SHORT since it pulled up ...I would pull the shock all the way out and check it next to you hanger yo need to have a few inches down so the wheel has room to sag as well as compress..easy check..
Hottrucks is offline   Reply With Quote
Old 03-29-2009, 06:27 PM   #10
nds1968
nds1968's Avatar
Your probably right. But I'm thinking a loose or too small of a bolt may cause that also like someone mentioned.
Nate
Old 03-29-2009, 06:29 PM   #11
vectorit
What?
vectorit's Avatar
X2 on that.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 03-29-2009, 07:04 PM   #12
69halfton
69halfton's Avatar
AHAHA im sorry, but that just plain made me laugh.
I read "is this common, or am i just a bad driver?" and then the first picture i see it the picture with the shock hanging and the mount all torn out
no words, the picture was self-explaining..
and I am trying to picture a "bad driver" doing something so outragous to bust it like that
..i dont know why I find this so funny, nobody else did... but I'm still laughing
no offense, it was just the wording and picture combo
- Jason
If you can turn, Youre not going fast enough.
Favorite caption:
first car to 200 mph in the 1/4 mile, no parachute, drum brakes all the way around..
..back when men were men.
69halfton is offline   Reply With Quote
Old 03-29-2009, 07:23 PM   #13
americanmusc1e
no offense taken
-- Josh
Old 03-29-2009, 07:49 PM   #14
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
I vote for, among other things, that it was loose. That didn't happen with one shot. If you lay a hammer on a piece of metal and press as hard as you can...nothing happens. If you barely tap on it a few hundred times, you will ruin the metal.
Bottom line...if that shock mount was tight....the shock would fail WAY before the metal would!!!!! Make sense? It was loose. May have been to long or short, but that didn't cause that. It was loose!
prostreetC-10 is offline   Reply With Quote
Old 03-29-2009, 08:07 PM   #15
americanmusc1e
makes sense to me.
Do yall think I can fix it by welding a THICK washer to the tab??????
-- Josh
Old 03-29-2009, 10:19 PM   #16
prostreetC-10
My Carbon Footprint
Originally Posted by americanmusc1e View Post
makes sense to me.
Only if you have dueling bangos playing in the back ground. I'd just get another shock mount and be done with it. All coil rear ends use the same one just get the correct side. Junkyard or eBay might be the best place. It's just too cheap a part to try and fix.
Old 03-29-2009, 10:49 PM   #17
69halfton
69halfton's Avatar
well id be replacing it if it was me, but if your deadset on fixing it, I'd grind it out until it was square then weld in a peice of steel the same thickness, and drill a new hole.
- Jason
Favorite caption:
Old 03-29-2009, 08:41 PM   #18
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
You're the worst driver I've ever seen!! J/K
Looks like you might get by with a washer for a fix.You want to make sure it is an extra thick one.I would look for replacement shock mount and new u-Bolts.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
