http://public.fotki.com/street
Tie Rods Don't Fit
I have instaled control arms and spindles from a 71 ( disc) into my 64. The tie rod ends from the 64 don't fit the spindles properly and the 71 tierods have a larger threaded end ( 11/16 " ) than the 64's ( 5/8 ")...PLEASE HELP
not sure exactly but are you sure you got a 71 clip not a 73 up?
If it is a 73 up you need to get a custom adapter sleve . CPP makes on check there web page . you can also search for "improtant info for you guys wishing to run 73 up spindles " or just go back a few pages on the susp board
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
Bills Truck Shop can also get you the stuff you need his number is 1 (905) 725-3460 tell him Mario sent you! Hey where in Canada do you live ?
Thanks for the help. I am from Winnipeg, Just north of Grand Forks. Just got a big dump of snow here so I should have lots of time to work on the old truck now
![]() Join Date: Jan 2002
TIERODS
You need all of the tierods and centerlink from the 71-72 truck.
I think you need the sleve I had the same problem I used 73 spindles on my 72 had a heck of a time getting tie rods to fit I ended up needing a new adaptersleve which came in the dorp spindle kitand a diffirent centerlink because the hole sizes changed somewhere between 70-71
